First post, by EvieSigma
I just acquired a Mitsubishi MP286L laptop in overall great condition but it was missing all of the disks it would have come with, including the very important Setup disk. Without it I can't go into Setup at all, as far as I'm aware. I did find another disk on the Vogons Drivers site but it was not the Setup disk, it was some kind of utilities. Does anyone have an image of the Setup disk?
Reply 1 of 17, by PC Hoarder Patrol
EvieSigma wrote on 2022-11-02, 23:33:
Not an image, but this maybe?...
Listing (dead) - https://www.mpoli.fi/files/hardware/SETUP/MITSU/index.html
Actual File - https://ftp.zx.net.nz/pub/archive/files.mpoli … re/SETUP/MITSU/
Reply 2 of 17, by EvieSigma
PC Hoarder Patrol wrote on 2022-11-03, 01:14:
Not an image, but this maybe?... […]
Thanks! I tried it and it worked perfectly! Now if only the hard drive worked instead of just...doing nothing.
157.63 KiB
Reply 3 of 17, by PC Hoarder Patrol
EvieSigma wrote on 2022-11-03, 01:37:
Progress at least...maybe @Horun could add the setup zip to his utilities entry on Vogons Drivers!
Reply 4 of 17, by EvieSigma
I managed to get the drive to do...something but I'm currently trapped by an issue. The drive apparently has lost track of COMMAND.COM, and if I try booting off a DOS 3.3 floppy to copy COMMAND.COM to the hard disk, the computer can't do it. So I can't boot off the hard drive but I seemingly can't fix it either...is there even a way around this?
149.88 KiB
Reply 5 of 17, by PC Hoarder Patrol
EvieSigma wrote on 2022-11-05, 17:13:
What do the SET PATH & SET COMSPEC variables return at the C> prompt?
Reply 6 of 17, by EvieSigma
PC Hoarder Patrol wrote on 2022-11-05, 18:05:
That's the thing, the C prompt doesn't let me do anything except try and enter the path of COMMAND.COM, I can't figure out how to break out of that.
Reply 7 of 17, by PC Hoarder Patrol
EvieSigma wrote on 2022-11-05, 18:23:
Do you have any access at all to the C drive from a floppy boot, to at least TYPE or COPY the config / autoexec files on that drive or to do a full directory listing?
Reply 8 of 17, by snufkin
...if I try booting off a DOS 3.3 floppy to copy COMMAND.COM to the hard disk, the computer can't do it.
What happens when you try to boot from a floppy? If you get that same 'Bad or missing...' message then check that COMMAND.COM is on the floppy and try entering "A:\COMMAND.COM".
Reply 9 of 17, by EvieSigma
snufkin wrote on 2022-11-05, 18:47:
So, I tried booting from a floppy and copying COMMAND.COM to C: (I know it's on the floppy) and every time it would just say "error writing drive C:".
Reply 10 of 17, by Horun
If you boot from floppy can you do a DIR C: or DIR C:\ from the floppy ??
If you cannot then there is something wrong maybe the HD is not set up proper (maybe wrong drive type ?)...
added: if you can do a DIR C: then you should try to SYS C: from the floppy (needs the SYS.COM file)
PC Hoarder Patrol wrote on 2022-11-03, 02:25:
Nice find !! I can make a new entry but cannot edit the files in an entry. Will make a new one and point it here for reference....
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
Reply 11 of 17, by EvieSigma
Horun wrote on 2022-11-05, 21:38:
If you boot from floppy can you do a DIR C: or DIR C:\ from the floppy ?? If you cannot then there is something wrong maybe th […]
Can I do a Dir C? That would be a no.
It says Type 13 on the bottom of the laptop so that's what I set the drive as...it's a Miniscribe 8425.
178.68 KiB
Trying to do a SYS C: gives the message "no room for system on destination disk".
Reply 12 of 17, by Horun
What does FDISK report ? In the MITSU286.ZIP is a FXDFMT.com which is FIXED-DISK PHYSICAL FORMATTER V 2.40
maybe you need to reformat the hard drive with it.
Reply 13 of 17, by PC Hoarder Patrol
EvieSigma wrote on 2022-11-05, 21:53:
Can I do a Dir C? That would be a no. […]
Seems oddly familiar! - https://www.reddit.com/r/computers/comments/7 … shi_mp286l_fix/ & https://imgur.com/a/nqhx5
Have you checked the CMOS battery is good and that BIOS settings are being retained once set?
Maybe try an alternate setup utility like GSETUP - https://www.minuszerodegrees.net/5170/setup/5170_gsetup.htm
According to the tech support docs the 8425 is 615 cyls / 4 heads - http://www.bitsavers.org/pdf/miniscribe/Minis … anual_Sep88.pdf
Reply 14 of 17, by EvieSigma
Horun wrote on 2022-11-05, 23:52:
I get this when I run FDISK and view whatever's currently on the hard disk.
143.07 KiB
When I try to run FXDFMT.com it does try to format the disk but then after a lot of noise it just gives up.
141.46 KiB
Reply 15 of 17, by Horun
Can you post a picture of that HD ?
From what I read the Mitsubishi MP286L has one internal floppy, one possible external floppy and a possible internal HD. Is it an external HD ?
OR Did I get that wrong ?
Maybe Check the drive to make sure the Terminator/resistor pack is installed since it is the only drive. http://bk0010.narod.ru/DRIVESPECS/MINISCRIBE/2709.txt.html
Also the HD is an old MFM drive and would not be suprised if it is failing (not many MFM HD's still work proper after 30+ years).
Reply 16 of 17, by EvieSigma
Horun wrote on 2022-11-06, 03:30:
Can you post a picture of that HD ? From what I read the Mitsubishi MP286L has one internal floppy, one possible external flopp […]
It's an internal MFM HD, yes. There's an external floppy port but I only have the internal floppy and HD.
My problem is, if it is truly dead, I don't have a replacement, and this laptop doesn't have any real way to add a solid state hard drive solution like a XT-IDE due to the lack of standard ISA slots.
Reply 17 of 17, by Horun
Ok. The only thing I can think of is to pull the cables off the HD and clean the HD edge contacts with Iso alcohol and check for a film or corrosion in the cable ends.
If Fdisk see's the HD then it could be something simple (or not)...
