First post, by atom1kk
Hi, is it somehow possible to allocate the letter D to my CD drive? the problem is, I have to partitions which are C and D. and even if I choose in properties to use letter D windows still does not change it.
the only possibility i found is to install DOS driver and than it is possible. But is there a possibility to do it without the driver?
Reply 1 of 12, by Horun
You have to change the HD D partition to E or higher before you can can set the CDROM as D. Read this topic: Need help with Windows 98se and drive letters
Letter Assigner is a tool that might work...
Reply 2 of 12, by atom1kk
unfortunately letter assigner didnt work for me. I assigned everything ,rebooted but than when i go to my computer the searching flashlight appears and the system doesnt work fine anymore. if i unplug my cd drive than everything works fine, c is at c and my second drive is at e. but as soon as i plug in the cd drive those error appears. hat to return to original to work it agian.
tried different things, only letter E works without any problems. but with the dos driver i can assign it also to D. thats strange
Reply 4 of 12, by willinliv
Thank you for this. I was worried about it screwing up my system based upon what @atom1kk found, but for me happily Letter Assigner did not cause issues and allowed me to move my other drive letters around before reserving a space for the CDROM. I cannot ever remember worrying about this stuff when I was a kid, maybe I was less discerning (or had less resources)!
Reply 5 of 12, by GunKneeNeon
Zeerex wrote on 2022-12-03, 16:49:
Use DLManip in autoexec.bat and use the MOVE command to move D: to G: example DLMANIP.com MOVE D: G:
I use it with all my machines as I always use partitions to keep media on the second one.
It doesn't work for me. In Windows DOS prompt, any option results in a error "CDS or DPB chain corrupted". In pure DOS mode, the LIST option only shows the C: drive.
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
Reply 6 of 12, by Horun
Hmm from a pure DOS mode can you access the other HD partitions ?
Reply 7 of 12, by GunKneeNeon
Horun wrote on 2023-12-16, 04:14:
Yes
Reply 9 of 12, by Horun
I still think you should try Letter Assign : http://www.vogonsdrivers.com/getfile.php?file … 131&menustate=0
Reply 10 of 12, by GunKneeNeon
Horun wrote on 2023-12-16, 17:59:
Yes, Letter Assign works. It has some disadvantages though, being a windows program(the dos version needs running in pure dos) and cannot be launched via a batch file. And it needs a reboot to finish the letter changing. I'm aiming at running dos games under Windows dos prompt, because I have a very incompatible mobo(CUSL2-C). I decide to use a sound card like ymf7x4, using it in Windows and ignoring the fact that it's not compatible with my mobo in pure dos.
Reply 11 of 12, by ElectroSoldier
In 98 you should be able to assign a new drive letter to the 2nd partition, Z: for instance. Restart.
It should keep that letter.
Then you can assign a new letter to the CDROM and restart.
Then you can assign a new letter to the 2nd partition and restart.
Does that not work at all?
Does the second partition always revert to D:?
Reply 12 of 12, by Horun
IIRC Win9x defaults to the Primary master IDE drive as C, Secondary master IDE as D, then goes to Primary slave E, secondary slave F, then the other partitions.....So if you have 2 HD's each as master Win9x kinda locks those as C and D..
could be wrong but is how on my one w98 box...
