ALD PCI5433 Manual
First post, by WJG6260
Hello all,
Recently, I purchased an ALD PCI5433. It's an obscure board, from a Chinese manufacturer, but it's notable for being the only known 486 with pipeline burst L2. I haven't gotten it yet, but plan on testing it and providing some numbers here.
I reached out to ALD and emailed them to ask about a copy of the manual. They sent me 4 BMP images, which I've since converted into a PDF and attached here.
For those of you with ALD boards, you might be able to get some info from them if it's not out there otherwise. They seem to still have some useful stuff!
For those who have the board, this might be of help.
Hopefully we can get a page going for it too on TheRetroWeb.
If anyone has any information on this thing, it might be interesting to hear. It seems to be a strange, late abomination. ALD boards are known for fake cache, so not much can be expected, but there's definitely promise in this board, at least on paper.
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
Reply 1 of 11, by mpe
Thanks for the manual. I also happen to own one mb with ALD chipset and PB cache.
Will wait for your findings, but II found it actually slower than other 486 PCI motherboards I own (such as PC Chips 919 or MSI4144).
IMHO pipelined burst cache organisation provides no benefit at 486 FSB speeds (25/33/40 MHz). A well optimised 486 PCI chipset, say Sis496 or UMC can achieve 2-1-1-1, L2 reads with 15ns SRAMs already. So having a pipelined burst SRAMs with 3-1-1-1 can't change anything (and is actually slightly slower due to pipeline lead time). PBSRAM was really a solution for Pentium 60 or 66 MHz FSB speeds which would not maintain fast burst timing with async SRAMs. It is just like EDO RAMs for 486/first Pentiums
It could play a role with FSB overclocking since 10ns SRAMs are pretty rare. However, my board seems max out at 40 MHz.
Blog|NexGen 586|S4
Reply 2 of 11, by Horun
Thanks ! I think some other member here figured out that the ALD marked chips are either UMC or SIS depending on which markings, sorry can not find the forum link now....
Reply 3 of 11, by computerguy08
Thank you both so much for this info, I made a new page for the board on TRW.
https://theretroweb.com/motherboards/s/ald-pci5433
Is it possible to have a BIOS dump for this board (either one, both ideally)?
These ALD boards are ultra-rare, anything related to them helps a lot.
Horun wrote on 2022-12-06, 02:29:
I've been researching ALD chipsets with a few others and came to the conclusion the infamous SARC RC2016 is possibly an ALD relabel (see DAT303), there's photo proof floating around that SARC RC2016 was used on the same PCB with an ALD 93C305.
So, hearing that ALD themselves could be a relabeler sounds interesting.
The attachment 1.JPG is no longer available
The attachment 2.JPG is no longer available
Reply 4 of 11, by Anonymous Coward
I also have a PCI5433, so this manual is useful.
Unfortunately, mine has the CPU soldered down and no cache. I was thinking to solder in the cache chips, but so far my board is not stable.
My board uses electrolytic filter caps, and BJT NPN transistor instead of a MOSFET...not exactly markings of a high quality product. I haven't had time to troubleshoot, but these are the first things on my list to check out.
I highly doubt the chipset on this board is remarked. At least I'm not aware of any other single chip 486 chipsets out there.
Even if the EDO and PLB support are less than useless on a 486, it's still pretty cool to see it work. These boards were from 1997, and I suspect the move to PLB cache was for reasons other than performance...perhaps it cost less.
Does your board come with the AMI or AWARD BIOS?
Reply 5 of 11, by computerguy08
There is at least one other single chip 486 design, from ADC, with a "NEC" marked ADC004 chip (I have my doubts that's a genuine NEC part).
https://theretroweb.com/motherboards/s/adc-adgw2
Unfortunately, this one is even more rare than any of the ALD boards, I don't know of anyone else besides me that has this board, with this chipset.
I have my doubts as well about ALD being a relabeler, they even had their own web page at some point.
https://web.archive.org/web/20010627211840fw_ … t/products.html
Reply 6 of 11, by Anonymous Coward
I’ve seen those ”NEC” chipset boards. I always figured they were remarked ALDs. I don’t think I’ve ever seen one with plb cache though.
Reply 7 of 11, by computerguy08
I've yet to find the ALD counterpart which this one was copied from.
The one with a known datasheet (the 93C488) doesn't electrically match mine.
Reply 10 of 11, by Anonymous Coward
Interesting. This is quite different than the one I usually see, which had a yellow PCB and looks more like the ALD board.
Reply 11 of 11, by mpe
I was finally able to play with this board. It has a ton of settings in BIOS some of which are uncommon and not obvious if they improve performance or not. Found it faster with L2 cache in flow-through than pipeline mode (there is a jumper next to the CPU).
With some tuning I was able almost to match performance of other modern PCI boards, except for a bit slower memory speed and write speeds.
With AMD 5x86 133 MHz, PCI Trio64V+ and EDO RAM I can get 13.9fps in Quake timedemo. Which is close to typical 14.1fps of my SiS496 boards do (MSI-4144 or Asus PVI-486SP3) and a little bit slower than ~14.4fps on UM8886 board (PC Chips M919) or ALI Finalli boards (PC CHIPS 918i or MSI4145). Not too bad. Maybe a further tuning is possible.
The board seems to come with CMA8819(A) clock generator with no datasheet and documented settings for 25/33/40 MHz only. However, the same chip is on my M919 where it is known to have more settings (and one more jumper for extra combinations). So perhaps overclocking is possible (and the pipelined burst cache could show it muscles at 50/60MHz FSB).
The attachment Screenshot 2023-01-04 at 00.08.46.jpg is no longer available
The attachment Screenshot 2023-01-04 at 00.06.29.jpg is no longer available
Blog|NexGen 586|S4
