First post, by underthebridge
Hello,
A while back I managed to acquire the Acculogic Rampat! plus expansion card (for my Tandy 1000 TL).
However, after searching extensively, I could not find the drivers that are supposed to come with it (only the regular Rampat driver disk is available).
The Rampat Plus floppy disk is clearly different. Also I can see by the instructions it's different (https://archive.org/details/ramp-at-plus-boar … age/n1/mode/2up).
Would anybody having the Acculogic Rampat plus floppy be kind enough to image it and share?
If so I'd be immensely appreciative.
For example, I know that certain users on this forum have it boxed (for instance Re: Bought these (retro) hardware today). However, I apparently don't have the ability to PM (yet).
Thanks in advance
Reply 1 of 16, by Horun
You need > 25 posts to PM afaik.
Did you try the regular Acculogic Rampat drivers ?
Reply 2 of 16, by Doornkaat
You can quote a post from another thread in your own thread so the poster gets notified about your thread.
frankmonk wrote on 2022-08-14, 15:14:
Finally found a boxed rampat! Plus that might go into a Tandy 1000TL/2
Reply 3 of 16, by rasz_pl
Doornkaat wrote on 2022-12-22, 05:46:
wait what? never seen that, neat
Reply 4 of 16, by underthebridge
Thanks for comments. I already tried quoting the user who had boxed Rampat plus but I'm guessing my post got lost in that huge thread. I guess I'll keep working on my post count in the meantime 😊.
The original Rampat drivers may work. It has software compatibility with LIM 4.0 EMS. What's included with that is Quadtel Expanded Memory Manager version 4.0 (MM.sys file), which is an Acculogic-specific version of the Quadtel driver.
The Rampat Plus though has hardware support for LIM 4.0 EMS. The installer is also different for the Rampat plus and it was released at a newer date (see attached). So the driver may be a later version- this is what I was really hoping for, also would be nice to run what's intended for the card. It would also be great to have drivers finally available to all as it really needs to be preserved.
    23.6 KiB
    61.61 KiB
Reply 5 of 16, by douglar
My experience with a RAMpat+ and extended memory is your bios recognizes it or it doesn’t. There’s no driver that you can load after it boots to change that.
Expanded memory will need an EMM driver.
There is this thread: Acculogic RamPat! (plus) drivers
Reply 6 of 16, by underthebridge
douglar wrote on 2022-12-22, 15:31:
Thanks- you may well be right. Though the fact remains that still don't know what's actually on the Rampat Plus disk. The manual has been scanned, but oddly no disk content has ever circulated (unlike the original Rampat disk).
Hopefully someone can change that soon... 😉
Reply 7 of 16, by Cloudschatze
underthebridge wrote on 2022-12-22, 00:49:
Attached.
Be sure to supply the undocumented "/Z" parameter with the other MM.SYS switches. 😉
    RPPLUS14.ZIP
    386.58 KiB
    59 downloads
Reply 8 of 16, by Horun
Cloudschatze wrote on 2022-12-23, 04:13:
Attached.
Thanks ! added to my archive and will add it to Vogons Library this weekend.
Reply 9 of 16, by underthebridge
Attached.
Perfect 👌. Thank you kindly!! 🙏
Nice to also see being added to vogondrivers. If desired could also include manual (linked above), and original Rampat drivers (ftp://oldskool.org/pub/misc/Hardware/Acculogic/ ).
I'm slowly working my way through archiving my floppies, at some point need to add all my stuff (maybe the onset of winter will make that easier...)
Reply 10 of 16, by douglar
Attached.
Windows Defender says:
Virus:DOS/Stoned_Monkey.B in DISKIMG/RPPLUS14.720
archive also contains Trojan:Script/Wacatac.B!ml
Reply 11 of 16, by Cloudschatze
douglar wrote on 2022-12-23, 14:38:
Windows Defender says: Virus:DOS/Stoned_Monkey.B in DISKIMG/RPPLUS14.720 archive also contains Trojan:Script/Wacatac.B!ml […]
Attached.
How embarrassing.
I've re-uploaded the archive with a 720K image dump from a non-infected diskette. Thank-you for the catch, douglar!
Reply 14 of 16, by Horun
I scanned the new .ZIP with Defender in Win7 and it found nothing (using last weeks definition dated 12/16/2022), sure did in the old one 🤣
Also: if Defender flags a file I always use Virustotal.com to check it more thoroughly....
Reply 15 of 16, by mkarcher
douglar wrote on 2022-12-23, 17:51:
Windows Defender still says the archive has "Trojan:Script/Wacatac.B!ml"
False postive?
Quite likely. Wacatac.B is known to be prone to false positives. It's a kind of "this somehow looks similar to a trojan script" detection. As I understand it, the "ml" at the end refers to a detection supported by machine learning on a big database of software samples.
Reply 16 of 16, by Masaw
Use my DOS antivirus (it can handle several most common boot and file viruses without even the need to boot from clean system disk because it can disable the virus even if it's active) to remove Monkey viruses after you are done writing the disk image into a floppy disk or mounting it in VM/DOSBOX-X
    VCHECK.exe
    62.38 KiB
    34 downloads
    Virus Check+ for DOS v2.0 Beta
