First post, by Marco
Dear members,
I found out so far that DMA clock speed should be around isa bus/2 = ~4mhz
Questions:
- is there any benefit from higher dma clock speed?
- I run mine currently at 6MHz. My Adaptec SCSI BIOS test runs fine up to 5,7mhz dma speed. Then I just changed my dma clock to 12mhz (=ISA bus speed SYSCLK) Booting was ok. But adaptec scsi Tests weren’t successful on anything above 5,7mhz. Even 6,5 was not working. And never was. Why is that? Do I mix up things ?
- update: I noticed that IDE speed increases from 2mb/s to 2,86mb/s (fast 160gb drive). Shortly checked with NU SI
BR
1) VLSI SCAMP 311 | 386SX25@30 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | SG NX Pro 16 | LAPC-I
