First post, by beltrixx
- Newbie
Hi all,
I have an AMD K6-III retro build which runs pretty stable but, when it comes to the graphics card... I've ecountered some issues so I would appreciate a bit of advice.
My system has the following specs :
- Epox MVP3G-M motherboard with 384 Mb RAM (100 Mhz) and a K6-III 400 Mhz processor.
- Soundblaster Live PCI sound card
- Generic realtek RTL3189 PCI Ethernet card
- Promise PCI Ultra133 Tx2 hard drive controller (recently installed & set up)
- ATI 3D Rage IIc AGP card (currently)
System runs just fine but I would like to improve graphics performance; I do have a 3dfx Voodoo Banshee card (PCI) that is actually faster than the ATI AGP card I fitted but I'd rather prefer to use AGP port instead of PCI for graphics...
Months ago I fitted a Leadtek Winfast A250 LE TD (AGPx4) which had been in storage for decades and it ran fairly well but one of the capacitors was clearly worn and I had the bad idea (my fault) to take the card to a mobile phone repairing shop to replace it... the card never ran stable again so I decided to replace it by a similar card. I read some posts here, specifically the ones by PhilsComputerLabs recommending either a TNT2 Ultra or a Voodoo3 (What is the best graphics card for Super Socket 7? My journey :D)
Recently I acquired two second hand AGP cards (Abit Siluro MX-440 SE and Leadtek Winfast Geforce2 Mx64, both AGPx4) for little money, so I thought at least one of them would run but I had no luck. The first one worked (BIOS and WinXP didn't complained about it) but there was some sort of "blue colouring" since P.O.S.T. I couldn't get rid of... (white BIOS text during POST showed blue, for instance) and the Geforce2 simply didn't work, BIOS complained by beeping right after pressing the power on button.
Maybe I've had bad luck with both cards... Anyone here with a similar set-up that can recommend a fast (and stable) AGP card? Should I stay away from AGPx4 and strictly look for AGPx2 cards?
Thanks in advance,
Manel.
"...Never in the field of human conflict was so much owed by so many to so few..."
(W. Churchill, about RAF pilots during WWII)
