Capacitor Identification
Reply 20 of 22, by bogdanpaulb
1 - clear the pads with solder wick , that is a missing cap used for the soft start func of the buck converter controller ( 0.1uf) , get it from a dead board .
4 - use solder wick to clean the pads
2 - remove the second purple cap , use solder wick to clean the pads , check for short again. If is still there go to step 3.
3 - remove the coil from the board , use solder wick to clean the pads , check for short again. You should have short to ground only on 1 side of the coil . Depending on the side , i will guide you further.
    1.51 MiB
    1.5 MiB
Reply 21 of 22, by JayAlien
Thanks for the guidance. I see the missing cap now. I'll likely order one to ensure it's the correct value. If you have a mouser link that would really help
I removed the second purple cap and cleaned the pads with wick, still seem to have the short between the +12v and the GND. I'll remove the coil next and update
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX Xfi 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 22 of 22, by bogdanpaulb
Use a digital caliper or some tool to give me the length and the width from one around it , and i'll give you a link.
    1.51 MiB
