First post, by Velociraptor
- Member
I have an Omniview F1DA108P and other than one small problem it's ideal.
For some reason 3 out of the 5 PCs connected to it will detect as connected to monochrome monitors if, and only if, the Omniview is selected to their channel when powered on.
In other words if I switch on the PC in channel 2, while the Omniview has channel 2 selected then it will detect as mono. If it's selected as channel 1 or 5 or whatever at boot and I switch to channel 2 after POST then it's in colour.
One of the PCs will beep the speaker at POST if it detects mono, so I've been able to test the behaviour with no monitor connected, and it's the same. Mono if the right channel is selected.
I saw another one on ebay cheap, nearly the same model this is the F1DA108T, which adds a USB port to each channel. However even on that one the behaviour is the same, if the channel is selected at boot it detects as mono.
Does anyone have any suggestions?
