First post, by Nemo1985
Hello, I've bought some time ago the abit st6 which was in very bad conditions, probably kept in a barn with some water leakage, bulging caps and so on. I asked for a recap (polymod actually) and it was ready to get back on business.
Then a friend gave me a pc which inside I found the most wanted Socket 370 with intel chipset board the Asus, I so much regretted to have paid 40 eur for the abit...
Today I finally decided to do try them both, I decided to go with a Tualeron 1200mhz and then with a C3 cpu (just to check the compatibility) and in the end the fastest Tualatin around with a bit of overclock (bus 140mhz because after that new divisors come in place). Both motherboards have been tested with the latest bios available: 9P for the Abit and the 1014.001 beta for the Asus. Both motherboards have been tested with the tightest ram timings.
Long story short the Abit is always faster and the difference gets bigger with higher bus speed.
Memory performance are always better on the Abit
I've found the Abit more tricky and less stable than the Asus.
Asus bios is more complete but at the same time more sluggish to navigate, sometimes there is a consistent lag between the key pressed and the option being selected, the Abit bios has more voltage selection options for the cpu (no other overvolt options).
I also found that the cpu temperature reading on the Abit is bugged, it gave me crazy temperature values for the cpu while it was barely warm.
Both motherboards have annoying caps near the cpu socket but the Abit has a bit more space, probably because it use more caps but smaller size compared that the big crazy that are on the Asus. On the other hand the abit memory slot can be an hassle when a longer agp card is used at least the first 2 memory slots can't change the memory if the video card is in the agp slot.
I found the Asus to be more precise with the bus clock generation as can be seen on the following screens:
