First post, by Kordanor
I am currently using a Super Socket 7 board which doesnt have any off that. It just detects it automatically.
I'd like to change now to an other board because of
Finding a PCI Card with DVI which actually works might be extremely costly or just impossible.
There have been threads about that here: SiS 530 SS7 motherboard PCI compatibility woes
And here: PCI graphics card compatibility with SiS530 chipset
And various others.
I already bought a FX 5200 which doesnt work at all.
Bought a low End PCI Card to test now.
But then I would still need a proper card. Might buy a G4 MX440 which is close to the FX 5200, and might refuse to work as well (goes for 65€)
Then I could still try to buy a MATROX G450 for about 30€ and if that works, I might need to switch between the SIS and this GPU depending on what I want to do (DOS/Windows)
So best case: I spend another 65€ and it works (I somehow doubt it), worst case: I spend another 95€ and I am still no step further.
And I already got multiple AGP Cards lying around - if I just had the proper slot.
So I considered buying a different board with an AGP slot giving much more flexibility.
Now I know that you can only set CPU speed and multiplyer dynamically with an AMD K6 2+ or 3+, but I would like to be able to adjust these things with the BIOS at least without the need to change jumpers.
But it seems like most boards have these jumpers. In fact I haven't found a single one which doesnt have yet. Which brings me to the assumption/conclusion that it has to work even with jumpers somewhow. Will they just be "overwritten"?
Examples:
HOT-591P:
Here you set Frequency and Multiplier manually, Voltage can be set to automatic: https://minuszerodegrees.net/manuals/Shuttle/ … %20HOT-591P.pdf
Commate S7AX
Apparently you also set Clockspeed, Multiplier and Voltage manually: https://theretroweb.com/motherboard/manual/s7 … 70600910067.pdf
Aristo AM-954
Here as well: http://e.manualretriever.com/lect.php?ID=5204 … ecf8427e&src=15
MSI MS-5184
Same here: https://www.msi.com/Motherboard/MS5184/support#manual
