First post, by gordesky1
So i wanted to do a image of my 430cdt hard drive which went well with easyUSA than i put the image on a 6.4gb ide drive which came from one of my compaq laptops it image right over fine.
Pop it in the laptop and it just sits there on the memory counter for like 5mins than it will say non system disk or something.. Sometimes i can get in bios but it says no hdd even tho the hdd is powered on and running...
So i did a image of the stock drive again with linux this time it did it but yep same problem wont boot in the laptop.. So i took it out and put the stock one in and it booted right to windows 95 as normal....
Last thing i did was get another hdd even tho its a bigger one 20gb i know the bios cant support more than 8gbs but it resized it too 1.26gb when imageing. Pop that in same thing as the first drive sits at the memory counter for 5mins and says insert system disk...
Is there a limitation what idk kind of drives these will accept????
Unless im doing something wrong and missing something???
