First post, by AlessandroB
every time i add a new computer to my collection i have the usual problem of choosing the sound card. The target for everyone is DOS and win98 for the fastest, creative as the main choice… these are the current pairings: all are superstar in his family
PS/2 (286): SB2.0
PS/1 (387): SB Pro 2.0
PC330 DX4: SB16 CT1740
PC330 P60: SB16 CT1770 (the only cheeper one)
PC330 P200: AWE32 CT3900
Nervista P4 (SBlive 5.1 & not remember but the most dos comptible pci)
now come the PC 300GL with Pentium2 (80% dos and 20% win98)
Reply 1 of 31, by kolderman
AWE64 seems like an obvious choice to fill the gap between AWE32 and SBLive.
Reply 2 of 31, by kixs
AWE32 CT3980
Although P-II is more of a Windows machine. Not sure what DOS only game would need the power of P-II? As it seems you have all the DOS bases already covered.
Reply 3 of 31, by AlessandroB
kolderman wrote on 2023-04-08, 19:43:
I thought about it too, but being a dedicated computer like pc DOS the lack of opl3 is rather annoying
Reply 4 of 31, by kolderman
AlessandroB wrote on 2023-04-08, 20:02:
Then don't go Creative - get something different like an Aztech board or a crystal/ess board with real OPL on board. Lot's of choices. Or if you want to spend more, what about modern retro creations like AWE64 Legacy or Orpheus?
Reply 5 of 31, by AlessandroB
kixs wrote on 2023-04-08, 19:45:
AWE32 CT3980
Maybe I didn't explain well, this computer is used as a daily pc so as not to overuse the 486 and pentium which are becoming more and more rare and expensive. I use those when I want to test something period correct but for almost all games (which are not speed sensitive) I use the PII. For that it should have an opl3. I could put the awe32 in the PentiumII, but it seemed perfect for the Pentium200, and besides, what would I put in the pentium200??
Reply 6 of 31, by Shponglefan
Is a genuine OPL3 really that needed on a Pentium II system though? Which games are you playing that still rely on FM synthesis on a Pentium II?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 7 of 31, by bogdanpaulb
You can always go with the 'cheap' vibra16 revs. that have the yamaha chip on them ct2260/2890 or some other card that has the opl chip.
Reply 8 of 31, by AlessandroB
Shponglefan wrote on 2023-04-08, 22:00:
all the dos games, from dune2 to x-wing to monkey island ecc ecc
Reply 9 of 31, by AlessandroB
bogdanpaulb wrote on 2023-04-08, 23:01:
Is not so cheap, cost how much as a opl3 sb16 or awe32…
Reply 10 of 31, by bogdanpaulb
AlessandroB wrote on 2023-04-09, 07:10:
Here is something you should be able to find cheaper - Crystal, Rockwell, metallic audio jacks and genuine opl3 / fax modem bonus: https://www.ebay.com/itm/314452330626?hash=it … dIAAOSwQU1kCFAg and here is only the sound card with opl3 https://www.ebay.com/itm/255637385698?hash=it … IUAAOSw4EFi1ubj
Reply 11 of 31, by stanwebber
i like the modem card; it's a 3rd gen azt2316. the other card looks like a 2nd gen azt1605 which has more baggage. unless your bios is pnp avoid the 4th gen azt2320 cards (integrated yamaha opl3), but mine works great in my kt133a system.
opti 82c924/929/930 and als100/100+ cards will have a genuine opl3 or 1:1 clone as will the ess es688 (emulated mpu-401). i think one generation, of many, crystal cards had discrete opl3 chips, but i don't remember and i've certainly never seen one in person.
i'd pick an aztech card first, then es688 over an opti. (i don't have any first hand experiences with als cards). ess cards are really nice, but the lack of wss (despite what the documentation says) is a deal killer for me.
Reply 12 of 31, by Shponglefan
AlessandroB wrote on 2023-04-09, 07:09:
Why play those on a Pentium II though? You listed a whole bunch of other computers in the OP that already have OPL-based sound cards that are better suited for those games.
Reply 13 of 31, by bogdanpaulb
AlessandroB wrote on 2023-04-08, 20:11:
AWE32 CT3980
He wants a 'cheap', daily computer to protect the other 'old' ones.
Reply 14 of 31, by AlessandroB
ok, you convinced me, with this PentiumII I will use some card that is not strictly Creative as a rule (as you saw I always followed)
Let's see, suggest something like this:
-simple to setup and 100% DOS compatible with Sound Blasters
-that has good (excellent?) sound quality
-that has an olp3
-that I can install the X2GS weaveblaster card and use it in games
Reply 15 of 31, by kolderman
There are huge threads already dedicated to best ISA sound card. No point replicating all that here.
Reply 16 of 31, by AlessandroB
kolderman wrote on 2023-04-09, 21:46:
yes agree, i will find, tnks
Reply 17 of 31, by Pierre32
I'm probably going to build a PII system for DOS soon. I mostly play later stuff including Glide titles, and my current Socket 7 board maxes out at 200mhz (non MMX). I've got a Slot 1 board and PII 450 sitting here, so why not.
The sound card will just be something Yamaha or ESS based. Unexciting, but good quality and covers all the bases.
Reply 18 of 31, by reodraca
If you need DOS compatibility and that Yamaha chip is a must, there are always a bunch of Yamaha OPL3-SAx ISA cards on eBay. They're Sound Blaster 2.0 compatible in DOS, and sound great. They're not as beefy as an AWE32 in terms of wavetable features, but they get the job done, and the main chip that drives the sound is literally a more advanced OPL3 chip.
Reply 19 of 31, by AlessandroB
There is a slight nuance that I don't understand though, if the various ess or yamaha cards only set to simulate an AWE32, we might as well take an awe32 directly! so much the difference in price will be, looking closely, 50€, a spendable amount.
