First post, by jakethompson1
- Oldbie
Is there any pattern for motherboards that "erroneously" turn on the HDD LED when you access an IDE CD-ROM drive versus those that don't?
I suppose at this level there is no distinction between an HDD vs. an ATAPI device, so perhaps the issue is whether the secondary IDE channel should light up the HDD LED or not.
I'm using a P5HX board (430HX) and don't see anything about the LED in the PIIX3 datasheet, so I presume the LED is all the board designer's job and is just triggered by one of the pins on the IDE cable.
Was there any greater pattern in which boards trigger the LED based on secondary channel activity and which don't? I don't remember running into this on other boards.
