First post, by Le_Bassiste
.LOG
17:44 17.04.2023
hi all,
long time lurker here, absolutely amazed by this forum, which helped me tremendously in selecting suitable hardware for my retro build. so i thought, why not contribute something ...
many moons ago, german c't magazine author Andreas Stiller published a series of articles about the then commonly used 486 chipsets. he published a DOS program that would enable the user to tweak a particular chipset, using info from a bunch of register definition files for the various chipsets that contained the description of register addresses and register bits.
find attached in CHIP.ZIP the zipped *.CONF files for the various chipsets and the configuration program "ctchipz.exe". afaik, there's only a german description available, so here is the english translation of CTCHIPZ.DOC .
bear in mind though that i'm not a native english speaker, so your level of confusion may vary.
cheers and thank you for this fantastic forum!
reading and configuring chipsets
Chipset gives you the internal configuration of the most common chipsets (as per 1993). This requires a Configuration file (.CFG) for each chipset that you specify when starting the program. Configuration files for various chipsets have been published in c't magazines (c't 3, 4, 6, 7, 8/93). The following chipset files have been lastly added:
Shasta by Headland
Opti Pentium
IBM Blue Lightning
Opposed to the original publication in c't 3/93, the program has been expanded with two items:
- the ports can be 16 or 32 bits (needed for example for SiS-EISA)
- You can now not only read but also write chipsets (input: H + value in hex).
!!! WARNING !!!
Various types of changes are either not allowed at all (e.g. DRAM constellation) or not allowed in normal operation (e.g. changes to the {cache strategy:cache}). Failure to observe this will result in a CRASH. Other changes (like DRAM timing, waits etc.) depend on whether the board design can cope with the altered settings, otherwise, again: CRASH or MEMORY PARITY ERROR!
(Extended version from c't 3/93)
DOS : From DOS 3.3
Proc : From 8088
Modes : Real / Virtual on Windows, but not OS/2 or NT
Parameter: ctCHIPZ [config] [/index [value]]
Config: Name of the configuration file with the extension .CFG
(Alternatively you can also use Set Chipset=Config to specify
the name of the *.CFG file)
/index: index of the configuration register to be displayed.
for 16- or 32-bit indices you have to specify additional bytes:
index:0 (default) bits 0..7
index:1 bit 8..15
index:2 bits 16..23
index:3 bits 24..31
value: optional, writes the value into the indexed register.
