First post, by retrosalvage
Hi all!
First post after stumbling back into childhood history recently since my 386/DX 40 30 years ago!
I acquired a Neoware Ca2 Thin client and my goal is to see whether I can use it as a DOS gaming machine (mostly 90's adventure games).
I would like to install an ISA sound card. There appears to be an ISA slot (Is it really an ISA slot or what kind of slot is this?) It looks so modern 😅 I attached two pictures.
I would not be able to fit anything in there due to the restricted space. What are my options for anything like a ISA riser card, ISA expansion ribbon cable? I have read somewhere that there is an official riser card for this unit but I cannot seem to find anything. Is there anything else that would work.
Thank you!
RS
Reply 2 of 7, by retrosalvage
mscdex wrote on 2023-04-22, 14:08:
It's a special slot that carries both ISA and PCI signals (LPX motherboards use the same slot I believe) and in this case you'd […]
It's a special slot that carries both ISA and PCI signals (LPX motherboards use the same slot I believe) and in this case you'd need a low profile riser card like the one shown at the bottom of this page:
Thank you, I will see if I can source one.
Reply 3 of 7, by OldWingCommander
Good luck, I own a Neoware CA2 myself and luckily got the riser card already installed when I purchased the unit.
It’s currently running an ESS-1869F ISA sound card with no issues. If you have any questions in general about the CA2, I’m happy to answer them.
Reply 4 of 7, by retrosalvage
OldWingCommander wrote on 2023-04-23, 03:37:
Thank you, I see it has got a built-in Sound Blaster and settings in the BIOS. You do not perhaps know which DOS drivers I can try for DOS ?
Reply 5 of 7, by mscdex
This machine appears to have the VT82C686B (according to the pictures on this site), which is the south bridge that handles the built-in audio. You should be able to use this VIASBCFG utility and/or make sure your BLASTER string is set in DOS (according to your "Sound Blaster" BIOS settings) to get your sound working. The chip specifically emulates Sound Blaster Pro and MIDI.
Reply 7 of 7, by retrosalvage
I have been looking all over for this riser card. If anyone see something for sale, please let me know.
