First post, by ediflorianUS
Sorry folks , I am in a sort-of-a Pickle today , and I am doing a dual menu trade:
First off , After I managed to fix my internet properly , I booted my main PC (dell Precision) up, and as I did not use it for a while , I did not need anything than a basic GPU , my old(main) MSi 7750 GPU , was installed in a Alienware X51 system because it fit and was small enough , so I am leaving it there , maybe I can sell off (the Ali).(so please forget this one is not relevant for the trade).
Now my main PC has a problematic salvaged Nvidia Quadro FX550 , with improper cooling ... (it was pulled from my backup parts Dell Precision)
Issue is that its seems lacking in performance.... I checked techpowerup , and it turns out It-s the fastest PCIe working GPU I own ... (lolz) ,
I also found a working.fanless, Asus EN6200TC512/TD/256M/A (in my collection) second sticker sats SVAGA512GAS001 VGA 512M6200TC Asus (not sure if its 512 or 256? the point is , after checking the data for this Graphics card , it seems even more slower than the FX550)
Question is , what to do now? I don't want to spend $ on gpus , the new-ones seem old stock and are at outrageous prices (for someone like me that ocasionaly do stuff on that requires overt-the-top gpu perf).
I checked today my collection of broken gpu*(of hopes & dreams and promises), but not 1 posted. (except for the 7950GX2 that has 1 absentee memory module).
I was thinking if I keep current FX550 , what kind of cooling could I mount from my old stack of GPUs? or would it be faster the EN6200TC512?
Second option would be to attempt a repair on 8800GTXs I have , one use to boot w/artefact's , but today did not.
Should I take this endevour , is it worth my time? or should sit on FX550 , and if something working comes along upgrade... (I also have a arctic cooling silencer somewhere sitting gathering dust).
here is to everybody,on the forum, passionate of there G80s , me included, some fixing and parts,oc guide and specialized info on them. (I have 2x8800GTX 768MB, and 1x8800GTS 320mb ECS)
old stuff(part of the collection , maybe we can find cooling that fits?) :
My 80486-S i66 Project
Reply 1 of 11, by The Serpent Rider
G80 is not worth repairing, at least if you plan to use it daily in retro setup. You can make it functional for brief benchmarks, but that's it.
Out of all Tesla family of chips, only something that has low TDP can survive for long and that's with a cooler that won't let GPU heat up beyond 70C. Or alternatively something that can be manipulated with direct undervolting, like original GTX260/280 and, most ironically, GTX295 Revision A.
Reply 2 of 11, by ediflorianUS
hmmm god to know , so the G80 suffers from the Nvidia wafer fiasco also.... *I used hot iron on my M8700gt to temp-fix it, not seem to work on old G80... besides these 2 GPU's I have are old volt-modded than broken & de modded versions , so they got something burned from oc (that's how they ended up to me).
Reply 3 of 11, by shevalier
ediflorianUS wrote on 2023-05-15, 12:00:
A legendary performance card with a legendary idiotic heat spreader.
Look for a new chip, remove the heat spreader from it, solder it to the board, adjust the cooling system for thermal contact.
Suicidal mission.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 4 of 11, by ptr1ck
I find the Quadro 2000 to be good for Windows XP and very cheap these days. About the same power level as the 8800, but only like 62w. Still works well enough in Windows 10 also if that's your thing.
"ITXBOX" SFF-Win11
KT133A-NV28-V2 SLI-DOS/WinME
Reply 5 of 11, by ediflorianUS
The precision(I'm on win7 64bit) use to have a quadro FX1500 series , and I sold that one to get the hd7750 , but If I Find one on the cheap(quadro 2000 , not listed on ebay so no shipping is involved) ,I will upgrade the FX550 ... (this is flaky... may have a memory chip with improper contacts).
BTW Nice photo of the G80 , I never knew it had a heat spreader on the chip , I always remembered it was the chip itself (gray).
Reply 6 of 11, by shevalier
ediflorianUS wrote on 2023-05-15, 18:25:
Gray and fried. Alas.
These chips are all on thermal paste, not solder.
Reply 8 of 11, by shevalier
ediflorianUS wrote on 2023-05-16, 07:55:
These images seem to sugest tiny solder balls (BGA) .... not paste .... oh well who knows.
Thermalpaste, not solder paste 😉
For example, some P IV
Low-melting solder (gallium-based)
    72.64 KiB
    233.76 KiB
Reply 9 of 11, by ediflorianUS
"Finaly found a upgrade GPU for the old Dell Precision 490"
update , I buyed sunday a (partially)broken Quadro K4200 , 4gb gddr5 ,however, it gave a code 43 on the gpu under windows , and some horiz lines(after driver install) ....
Cleaned the whole thing , after dissasambly , then hot ironed evrything (gpu+ram chips) but had no effect , no progress was made.
Eventually I managed to find the bios and Kepler bin editor , so I used that and just keep lowering the frequencies till it was stable enough to not give code43. (rewrote the firmware/gpu/bios/bin 4-5 times)....
I got it to a point I can load CS:S (HL2 engine) , at 640x480 or 1024x768 ... but in other 3d it just gives me , blank screen for a moment, and sometimes it starts most of the times it goes out of the 3dx app...
- I am stuck , not sure what else to do , voltage is back to stock (in .bin file , and I gave a uper 0.025v room in case it needed)
How do I check if it's a ram module? or the GPU ? causing evrything? (to narrow down the problem , it also has some laptop style VRM/MOSFET's - would one of them be acting-up?
Reply 10 of 11, by shevalier
ediflorianUS wrote on 2023-11-02, 15:58:
https://github.com/ihaque/memtestCL
Works great on Radeons. At nVidia - it should be too, besides there is a CUDA version.
Test iteration 5 on 1500 MiB of memory on device 0 (Pitcairn): 0 errors so far
Moving Inversions (ones and zeros): 0 errors (156 ms)
Moving Inversions (random): 0 errors (156 ms)
Memtest86 Walking 8-bit: 0 errors (1266 ms)
True Walking zeros (8-bit): 0 errors (625 ms)
True Walking ones (8-bit): 0 errors (625 ms)
Memtest86 Walking zeros (32-bit): 0 errors (2531 ms)
Memtest86 Walking ones (32-bit): 0 errors (2516 ms)
Random blocks: 0 errors (203 ms)
Memtest86 Modulo-20: 0 errors (12031 ms)
Logic (one iteration): 0 errors (78 ms)
Logic (4 iterations): 0 errors (78 ms)
Logic (local memory, one iteration): 0 errors (78 ms)
Logic (local memory, 4 iterations): 0 errors (79 ms)
Test summary:
5 iterations over 1500 MiB of memory on device Pitcairn
Moving inversions (ones and zeros): 0 failed iterations
(0 total incorrect bits)
Memtest86 walking 8-bit: 0 failed iterations
True walking zeros (8-bit): 0 failed iterations
True walking ones (8-bit): 0 failed iterations
Moving inversions (random): 0 failed iterations
True walking zeros (32-bit): 0 failed iterations
True walking ones (32-bit): 0 failed iterations
Random blocks: 0 failed iterations
Memtest86 Modulo-20: 0 failed iterations
Integer logic: 0 failed iterations
Integer logic (4 loops): 0 failed iterations
Integer logic (local memory): 0 failed iterations
Integer logic (4 loops, local memory): 0 failed iterations
Final error count: 0 errors
Press <enter> to quit.
Reply 11 of 11, by ediflorianUS
shevalier wrote on 2023-11-02, 16:32:
tnx I wil try-it
