First post, by pentiumspeed
The regulator this SBC uses is dumb regulator fixed voltage using EZ1083CT-3.3V but it outputs at 3.5V and there's no jumpers to adjust.
Made the chipset to run hot. I knew that Intel specified between 3.2V to 3.45V but I don't see 3.5V as max.
I wanted to fix this by running at straight 3.3V by replacing the regulator with adjustable type.
Cheers,
Great Northern aka Canada.
