clb wrote on 2023-07-28, 07:01:
The aspect ratio on the display is wrong? Looks like it displays maybe 16:10? https://liliputing.com/wp-content/uploads/202 … dos-book_04.jpg .
No pass from me, but then again, I have been pixel peeping PC aspect ratios for the past year and a half or so..
Yes, that's right! Err, I mean wrong. The aspect ratio, I mean. You were right it was wrong! 🙂
Though, that also happened with real 8088/V20 notebooks in the 80s.
Many had low-end models CGA graphics and a passive LC screen, with 200 lines.
These looked even more rectangular than this one.
The better models used line-doubling and had 400 lines. Some could even use 640x400 resolution.
Thanks to the Olivetti graphics mode, which is a compatible extension to plain CGA.
Example of such DOS laptops with CGA graphics :
Source: https://en.wikipedia.org/wiki/Poqet_PC
Source: https://wiki.preterhuman.net/Tandy_1100_FD
Source: https://en.wikipedia.org/wiki/Toshiba_T1100
the3dfxdude wrote on 2023-07-29, 01:48:
It's CGA because of the hype around the original PC/XT, and that the IBM schematics are readily available. It's pretty clear from the individual who made it, that is what he wanted to do, recreate something that is basically an XT hardware wise. OPL2 support is much the same way -- hype and plenty of clone designs to base off of.
+1
The problem is, that it's a big failure to many people ('You had one job' meme).
It's as if someone goes for an 100% authentic all-IBM setup, but then uses a cheap black/silver 16:9 TFT as a monitor.
That's such a provocation. Because it ruins the otherwise nice setup.
In fact, even an old 1950s NTSC TV set sitting atop a PC 5150/5160 chassis would have been more appropriate.
That may sound like an exaggeration, but it sadly isn't. A vintage TV is 4:3 and compatible with NTSC timings of a CGA card.
Via RF modulator, it would look very nice, actually. Like an NES hooked up to grandma's TV in living room way back in the 80s.
betamax80 wrote on 2023-07-29, 00:14:
Indeed. PCjr and Tandy 1000 compatibility would have mad so much sense on a retro device like this! 4-color CGA was always so limiting, even back in the day. Especially since the Book 8088 apparently doesn't support composite output that would allow 16-color CGA with some games.
I do second that, but I don't know if the chips are obtainable etc - I feel like there is a reason the creator went with CGA and OPL2. I completely see how something that "fakes tandy mode" would be awesome.
The original AdLib was easy to build and had a simple bus interface.
And many games supported it, for many years.
Tandy 3-Voice would have been even more authentic for early-mid XT era, but game support quickly dropped in the late 80s.
By comparison, AdLib had an universal cult-status and higher audio quality.
The EGA/CGA releases of sophisticated point&click games like Rise of the Dragon supported AdLib, but not Tandy anymore.
Same goes for Legend games etc. They still could support CGA as a fall-back, but not Tandy 3-Voice.
That's why I'm a bit disappointed about the "digital CGA" approach.
A blurry little composite TV panel and a composite circuit (colour burst circuit) would have been definitely possible.
There are microcontrollers like Arduino which can generate at least a monochrome "composite" video signal purely in software.
Such an approach would have been nice here. On a small sceeen, artifact colours wouldn't look that bad, even if resolution was low.
Edit: Maybe it's also a generation thing, not sure. These days, "makers" buy their stuff from AdaFruit, AliExpresss etc.
The LCD screens are the typical digital types meant for use with Raspberry Pi, Arduino, ESP32 etc.
Back in the 2000s/2010s, retro gamers upgraded/fixed their Sega Game Gears by replacint their CCFL-backlith LC displays by modern panels or LED backlight.
See https://www.youtube.com/watch?v=CRBP7DAK2bM
