First post, by fractal5
I have two computers with audio cards, these are regular PCI audio cards, one for a DOS era computer, one for a Windows 98 era computer. I'd like to connect both of them to the same pair of speakers.
Everything is 3.5 mm TRS.
I've tried with a passive "dumb" mixer (which isn't really a mixer) that just connects everything together in parallel. My Sblive! (in the win98 computer) can handle this just fine, however, the AWE32 in the DOS computer becomes so low in volume that I can hardly hear it. I need to turn the volume way up, and that introduces a lot of noise in the speakers.
This isn't a good setup. So I think I need an active mixer with a built in amplifier so I can individually control the amplification on each signal that goes in.
Basically I need a "3.5mm TRS Audio Splitter/Mixer" from what I understand.
Seems most of these are meant for 3.5 mm TRS input, but provide 6.3 mm unbal output. I need 3.5 mm output.
Any recommendations?
Should I just get one that does 6.3 mm output and use a converter?
