First post, by AmbassadorCosh
I don't see a max output on the sticker. I see resellers online listing it as "90w" but that is the +5V +3.3V.
The model # starts with 150..is it safe to assume 150w?
It's a 150W PSU that is rated for max 90W on 5V and 3V3 combined. Pretty bog standard for early AT systems.
90w 5v+3.3v is really nothing special and the 12v doesn't have much oomph either, I'd avoiding using it if you can. Hipros are not known for be especially reliable and it'll probably let out the magic smoke sooner rather than later. If it's all you have, I'd highly recommended testing the rails to see if they're still within spec with a multimeter, and doing so periodically.
Should be enough to power up average Pentium MMX system or older, but not much more.
Agree ! Good for a test/bench PSU for low end ATX boards if all voltages are within spec but only with minimal components.
NTG2001 wrote on 2023-08-15, 22:36:Hipros are not known for be especially reliable and it'll probably let out the magic smoke sooner rather than later.
The big problems with Hipro are cheap caps (not always a problem - even Su'scon caps last a long time in them) and lacking protections. I've never had one blow up under normal conditions, but they can be massively overloaded until they blow up instead of safely shutting down. I've also seen them smoke hardware where something shorted. They tend to be overbuilt to compensate.
I think it's fine for socket 7 or the low-power slot 1 CPUs.
lti wrote on 2023-08-19, 20:52:even Su'scon caps ...
Sorry
FCKGW-RHQQ2
