First post, by vmr_
Recently I came across an AMERICAN MEGATRENDS 286 motherboard, but unfortunately it is missing the BIOS chips.
Wondering if members of the Vogons forum have this motherboard in working condition to get a copy of the BIOS chips images and the chips model to be used for BIOS - to restore this motherboard.
The motherboard jumper config and specs are available here: https://stason.org/TULARC/pc/motherboards/A/A … OTHERBOARD.html
Attaching also a photo of the motherboard.
Any support is greatly appreciated 😀
    352.94 KiB
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 1 of 18, by dominusprog
The board is missing the BIOS and keyboard controller (socket on the top-left). This board has two BIOS, Low and High. Try the link below.
The Retro Web
https://theretroweb.com/motherboards/s/digico … -286v#downloads
Reply 2 of 18, by weedeewee
dominusprog wrote on 2023-08-18, 11:30:
The Retro Web
that's not the same mainboard though. similar. not the same.
this is the 'microhouse' manual... though no idea what the link is between the microhouse id and theretroweb page
https://theretroweb.com/motherboard/manual/33640.pdf
oh well, found it
https://theretroweb.com/motherboards/s/ami-28 … board#downloads
Do not ask Why !
Reply 3 of 18, by vmr_
Thanks @dominusprog, indeed the keyboard controller is also missing. Wondering how to find a replacement for keyboard controller as well?
Reply 4 of 18, by dominusprog
vmr_ wrote on 2023-08-18, 11:39:
https://www.ebay.com/itm/304566752199?hash=it … ABk9SR87uzofBYg
Reply 5 of 18, by vmr_
Thanks @weedeewee, also checked here for 286 BIOS images - so far no luck
80286 BIOS image collection
Reply 6 of 18, by dominusprog
weedeewee wrote on 2023-08-18, 11:38:
He/She is looking for BIOS, not manual.
Reply 7 of 18, by vmr_
in the absence of original BIOS image, I came across this list of generic BIOSes for IBM compatible boards/machines: http://www.minuszerodegrees.net/bios/bios.htm
Will give it a try for the 286 version, using W27E257-12 EEPROMS - once chips arrive.
Also came across XTIDE Universal BIOS - wondering if this would work as BIOS replacement for my 286 mobo.
https://www.lo-tech.co.uk/wiki/XTIDE_Universal_BIOS
Are there any other "generic" BIOSes for 286 known to work on a wide number of motherboards?
Reply 8 of 18, by zyga64
So, why not try bios image from link in post #2 provided by dominusprog ? This motherboard have exact same chipset, so it (probably) will work just fine.
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 9 of 18, by vmr_
@zyga64 will try it for sure, I missed that link for BIOS with HI and LO images.
Also found MR BIOS generic 286 VLSI bios - to also try it. Have a few options now, the long wait to get the EEPROM chips from China starts today 😀
Reply 10 of 18, by Anonymous Coward
If this board was manufactured by AMI, it would really surprise me, because all of the ones I've seen are clearly marked with the manufacturer's name, model name and series number.
Reply 11 of 18, by dominusprog
The link below will provide both High and Low in a single zip file. You can also modify the ROM before flashing them using the BIOS Patcher. Check out Necroware on YouTube for tutorials.
BIOS
https://theretroweb.com/motherboard/bios/ftk- … 13708064340.zip
Necroware
https://www.youtube.com/watch?v=VwZT40sRMzM
Reply 12 of 18, by vmr_
while waiting for the EEPROMs and keyboard controller to arrive, I dug out from storage another 286 VLSI motherboard (not same model, but at least another VLSI chipset) - so planning to test with these EPROMS and corresponding keyboard controller.
Motherboard with 'new' AMI BIOS and keyboard controller chips - not powered yet.
for validation with community: the even BIOS chip goes in the lower / even numbered socket U50 ; the odd BIOS chip goes in the upper / odd numbered socket U51
    293.73 KiB
    93.39 KiB
Reply 13 of 18, by dominusprog
Odd is High and Even is Low.
Reply 14 of 18, by vmr_
dominusprog wrote on 2023-08-22, 15:03:
the board missing the chips has no HI/LO marking - just judging by socket numbers 😀
what could possibly go wrong if I switch the BIOS chips?
Reply 15 of 18, by TheMobRules
vmr_ wrote on 2023-08-22, 15:07:
No danger at all, other than the board not working at all due to being unable to execute BIOS code. In that case just swap the chips and try again.
Do take care of installing the ROM chips in the correct orientation though.
Reply 16 of 18, by vmr_
TheMobRules wrote on 2023-08-22, 15:13:
thanks for clarification, will give it a try soon and share the update here 😀
Reply 17 of 18, by vmr_
Well, first test done - with somehow unexpected 🙁 results: one of the tantalum capacitors close to power socket exploded with a bit of fireworks and smoke.
Luckily the board was mounted in an enclosed case, so it was contained.
Maybe a full recap is required to replace all those tantalum capacitors? or just the burnt one?
