jakethompson1 wrote on 2023-08-19, 02:17:
The SiS 471 datasheet (https://cdn.hackaday.io/files/183453784885315 … asheet_text.pdf, p. 28) doesn't have that as a supported configuration. It would need to allow: 1Mx36, 1Mx36, 1Mx36, 4Mx36.
Are you messing with cutting down cache timings/RAM wait states, and multiple VLB cards? Others have reported the greatest success with one big SIMM anyway rather than filling up the slots with smaller ones like this.
At this stage I'm just trying using defaults and I can pick from many ISA and VLB cards, so nah, it doesn't depend really on combination of cards or cache/burst/WS settings.
You was right: the 4-4-4-16 combination is not listed as suported in the datasheet, so I tried 4-4-16-16 with known good modules and got my 40 MB working, as well as 16-16-16-16=64M, so probably the slot isn't malfunctioning. By the way, it doesn't matter if I use ECC or non-ECC modules.
However, it doesn't accept 8-8, giving the same 1280 (yes, not 1080 but actually 1280 ) kilobytes and it doesn't really matter which slot combination I'm using for two two-sided 8M modules, but single 8M in Bank 0 works fine with either of available modules. Also, when I try to insert 8M modules into Bank 0 and Bank 2, it gives me 12M but passes the test.
So, I can live with 24M or even 40M configuration but still can't get why I can't reach 48M with 8-8-16-16 combination. I have two 16M non-ECC modules and two ECC which I would like to keep for another machine which doesn't accept non-ECC, so I'm trying everything to get the maximum capacity from what I have.
Chkcpu wrote on 2023-08-19, 16:13:Hello rpocc, […]
Hello rpocc,
Further down in this thread I posted an updated 11/28/95-SIS-85C471B/E/G-2C4I9PA0-00 EPox-GXA486SG-Rev-J.1-BIOS.
Regards, Jan
Wow, that's a great news!
Currently I'm using this BIOS:
Award Modular BIOS 4.50G
4DMS-HL3GC AWARD BIOS REV 1.05 01/12/'96
12/07/95-SIS-85C471B/E/G-2C419E30-00
https://mega.nz/file/wXVhhaoQ#3kIFPp1hOYKo7Fp … VtmYD-bkY1FaBJ8
It does support Cache WB but I wasn't able to make it work with 5x86.
Currently I have 2x AMD-X5-133ADW CPUs and can't test neither of those because I don't have a single later board like one based on Sis496. Would be super-cool to run this on my Sis471.
Could you please suggest the right jumper/RA settings for this stone to enable 4x multiplier? AFAIK it requires 3.45 Volts and it seems that my MB only can give 5V or 3.3V using a regulator. From the standard AMD DX4-100 settings I've set the resistor array to RP12 position (5x86), and JP14 to 1-2 as suggested in the table. The position of JP20 doesn't seem to matter.
So far:
I have two 5x86 processors and maybe one of them is fake because they start differently.
One to my surprise has successfully started but recognized as Am486-S at 100 MHz both with your BIOS (which seem to be superior to mine) and my last BIOS.
The other one doesn't start at all. Maybe the first one is actually fake or has smoother voltage tolerance. Or, simply, the second one is dead.
P.S. If this counts, my board has 4x64K+32K cache configuration
P.P.S. I've connected two pins as suggested at the x4mult post by connecting a free pin of J25 with free GND pin of another jumper and it seems that I've got the X4! CPUID in Speedsys shows 04F4 and Y2K bug is shown as present. And yes, now during post it's recognized as 5x86 CPU @ 133 MHz!
