First post, by egbertjan
Is there a way to read in MS-Dos which bios version is on an S3 Virge DX / GX and at how many MHz the memory and the gpu are running? Is there a program to do that?
I have 4 different s3 Vrige DX cards and 1 S3 Virge GX and would like to know how fast they are and what bios version they have.
Reply 1 of 9, by dominusprog
Use NSSI.
Download
https://navsoft.cz/products.htm
Reply 2 of 9, by egbertjan
dominusprog wrote on 2023-08-19, 19:21:
Use NSSI.
Download
Thanks for your reply. in this program i can only read the bios version. Now I'm looking for something to read the GPU and memory speed
Reply 3 of 9, by rasz_pl
GPU speed will be zero because its not a GPU 😀 Afaik all Virge run ram synchronously, and you should be able to read clock from the BIOS. You should also consider type of memory on board.
http://files.mpoli.fi/unpacked/hardware/displ … 3b.zip/mclk.txt
Reply 4 of 9, by dominusprog
No matter which software you use, you can only get basic information about the model and BIOS version. Like @rasz_pl mentioned for memory type and speed you have to search the part number of the RAM chips.
Reply 5 of 9, by zyga64
mclk can read memory clock of virge.
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 6 of 9, by dominusprog
zyga64 wrote on 2023-08-20, 19:30:
This program is for changing the memory parameters on a bunch of S3 and Cirrus Logic chips.
Reply 8 of 9, by The Serpent Rider
rasz_pl wrote on 2023-08-20, 01:32:
No, Virge GX/GX2 have chip/memory dividers.
Reply 9 of 9, by rasz_pl
The Serpent Rider wrote on 2023-08-21, 02:01:
ah yes SDRAM/SGRAM Re: How to overclock an S3 Virge?
