First post, by egbertjan
Which s3 virge DX driver should I use under Windows 98 SE. I am now using the standard that comes with Windows 98 SE. The PC crashes during the race in 3dmark 99 and also when I do the direct 3d test in dxdiag. This all works if I do this with the voodoo 2 card in the same PC. The drivers I can find on the internet for the s3 virge dx are all for Windows 95 and older than the standard Windows 98 SE driver. Which driver do I need to solve this problem in Windows 98 SE. I tried this on different s3 virge dx cards all 4MB memory.
Can an s3 virge dx 4mb even run 3dmark 99?
