All Microsoft Serial/PS2 devices require a true Microsoft adapter (or one wired as one, there are other topics here about it) so using any old generic adapter has a 50%+ failure rate.
If the mouse or trackball is already PS2 then you def need a specific adapter to convert back to Serial. I have a few MS serial/ps2 mice and most of them came with an adapter.
My MS Intellimouse Serial/PS2 says same thing as that box picture and included the PS2 to Serial adapter and it works on all the MS Serial/PS2 that are PS2 native,
conversely have MS serial to PS2 adapters and they work on all wired serial. If wired for Logitech or Mouse Systems it generally will not work with a MS device.
So you need to search out the wiring of MS adapter and match it. Good place to start: Serial port with PS2 adapter.
Also you want to use the DOS Intellimouse driver, no Cute Mouse or Logitech or other...just MHO
