First post, by mrgreen
Hello,
Now I have a lot of RAM module sticks each on a single plastic bag into a card box. RAM modules are SIMM 30, 72, PC, DDR...
However, it's not so easy to manage them in this way.
How can I store them in an effective way?
Are available some kind of RAM boxes?
My first PC had Windows 98 os.
Reply 1 of 10, by DerBaum
https://www.thingiverse.com/barreljack/designs
I remixed some 3d printable Ram stands for all kinds of ram modules.
The things my remixes are based on are for newer ram modules.
I also made 3D printable CPU trays.
https://www.thingiverse.com/thing:4598121
My trays also got remixed into different CPU types.
FCKGW-RHQQ2
Reply 2 of 10, by alvaro84
A less professional but cost effective way I use - are 3.5" HDD boxes. As long as as a DIMM, as wide as a SIMM-72, they contain many modules in my cupboard.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 4 of 10, by Shponglefan
I use small plastic bins with dividers to store RAM modules.
    454.37 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 5 of 10, by Nexxen
Shoes box and zip bags (tested and untested).
Plastic box + antistatic bags with the ones I actually use for my builds (tested).
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 7 of 10, by Horun
I am cheap and use those mini anti static backs labeled in a cardboard box. For 30 pin keep them in sets of 4, 72 pin are in pairs and have many DDR, DDR2, etc in those retail clam shells they come in.
Also have some anti static bags with a few dozen in each, markered to tell me what they are 😁 like I said am cheap.....
I cannot do as Shponglefan has, our humidity in summer is too low and being loose in a nylon/plastic box and just opening/touching one could zap it....
Reply 8 of 10, by Errius
Yes, those DIMM trays on eBay. They can be stacked too, which is convenient. You can get large ones for DIMMs and small ones for SODIMMS (which can also hold DIMMs sideways). I have separate trays for SDRAM, DDR, DDR2, DDR3, RDRAM and miscellaneous.
Problem is oversized modules, which won't fit because they're too tall, and SIMMs, which are too small. These get 'stored' in piles, which I know is not good.
ETA: https://imgur.com/ObzvGyr
Is this too much voodoo?
