Unmarked socket 370 motherboard
First post, by andreipasca
So I've helped a friend clean their house and he gave me some old PC hardware. There was this Pentium III PC, that I took apart and cleaned. Then I tried starting it with only Mobo, RAM, AGP video card, and original PSU. All the AGP 2X cards are also from this friend and I have no other ago compatible motherboards to test the cards. The problem is I have no video. It posts long continuous beeps. And I have no idea what the POST codes mean as I have no clue what model and make is the Mobo. Can you guys help me identify the make and model of the Motherboard or give any advice as to what the problem might be?
Shuttle HOT-685 , Intel Celeron 466, Intel i740 4mb, 64mb SDRAM
Reply 1 of 26, by Nexxen
https://theretroweb.com/motherboards/s/shuttle-hot-685
It should be sporting an Intel chipset if the silkscreen is correct (440BX)
Model on yours is 685V12A, probably not relevant but it's close enough.
Beeps should be ram related, reseat ram stick if no go clean with some deoxit (contact cleaner) or change ram slot.
Also clean the contacts on the ram stick, some alcohol or an eraser will do.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 2 of 26, by Repo Man11
Did you install a CMOS battery after you took the photo? Some motherboards won't POST without one.
If you have a PCI video card, I'd try that. That motherboard may be very selective about what AGP video cars will work - low power AGP slots were pretty common back then. I'd also try another power supply if you have one. You can use the case's reset switch as the power switch if you use an ATX PSU.
Reply 3 of 26, by dormcat
andreipasca wrote on 2023-09-13, 15:38:
Nexxen had already identified the MoBo for you, but even if he didn't you should be able to see the shiny Award sticker on the BIOS chip at lower left corner. POST beep codes can be found online with a quick search; long continuous beeps mean your RAM strip might be faulty: not seated properly, oxidized contacts, corrupted chips, etc. I'd start with using deoxidizing contact cleaner on both the DIMM and the slots; if you have more SDRAM modules around then test the system with different strips.
Reply 4 of 26, by andreipasca
Nexxen wrote on 2023-09-13, 15:42:
https://theretroweb.com/motherboards/s/shuttle-hot-685 […]
I have seen the model before but no results came up on Google. So I figured it's an OEM board that has the same/similar layout as one from conventional brands. Already cleaned the DIMMs and the slots. I've tried booting it with the old CMOS battery and without one. Will try with a new one.
Reply 5 of 26, by andreipasca
Ok, I cleaned it again with deoxit, swapped the CPU with another Celeron, all same. Then swapped back to the original Celeron CPU. Now when I insert the RAM in the first DIMM it gives me the long beeps but when I insert it in the third DIMM I get one long and three short beeps. What could it be?
Reply 6 of 26, by Repo Man11
My take would be that one RAM slot has issues, and when you use the other then you get as far as an issue with the video card. So I'd leave it in the slot where you get one long and three short, then try a PCI video card.
Reply 7 of 26, by Nexxen
Repo Man11 wrote on 2023-09-14, 00:42:
From ram to video, that's progress! 😀
Yes, PCI card if he has one.
I think he's getting closer to a working system.
Reply 8 of 26, by andreipasca
Nexxen wrote on 2023-09-14, 01:23:
From ram to video, that's progress! :) Yes, PCI card if he has one. […]
I have magically managed to make it work with that RAM bar in DIMM 2 and a S3 video card. It turned on and booted. Then I connected the HDDs (some weird wide socket HDDs not IDE that connect via a PCI adapter), CD ROM, and the serial/parallel/etc expansions via MoBo sockets. Now it's not displaying anything again. Any tips?
Reply 9 of 26, by Repo Man11
andreipasca wrote on 2023-09-14, 10:17:
The power supply is ancient, and was probably barely adequate when it was new, so it could very well be the culprit.
Reply 10 of 26, by shamino
Do you have a multimeter? If so, try checking the +5V and +12V voltages from one of the unused drive connectors.
That's an unusual board. Not many socket 370 motherboards have AT power connectors. Those were obsolete when this board was new. They would have only been included to encourage upgrades for people who already had an old power supply.
Depending how the board is designed, an ATX power supply might help it to work better with more video cards. That's because ATX power supplies provide 3.3V and AT power supplies don't.
Reply 11 of 26, by PcBytes
shamino wrote on 2023-09-14, 11:54:
Not uncommon, these were about the last consumer platforms to be on baby AT.
file.php?mode=view&id=173723
Here's a similar board, a Luckytech P6VBX7. Note the AT and ATX connectors. As for running them off AT PSUs, I can say mine does work fine off an 200W AT PSU, though I've had mine recapped entirely after experiencing issues similar to OP.
So to answer OP's issue - replace ALL capacitors on the board with good new caps and it should work.
Reply 12 of 26, by mmx_91
I won't recommend to use AT power supplies with AGP video cards on these kind of boards (also SS7 boards).
As long as the PSU does not supply 3.3v, there is a VRM phase to do that and it can get easiliy overloaded with everything more powerful than let's say a GF2 MX or similar.
Better use ATX power supplies that can deliver 3.3V on their own to be safe.
Reply 13 of 26, by shevalier
and this does not affect dual-power motherboards at all.
If there is an AT power connector, then the motherboard always has a converter from 5V to 3.3V, and always uses it, even with ATX PSU.
PS. Some have jumpers “to bypass the built-in converter,” but it would be better not to have them, it’s so crookedly implemented.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 14 of 26, by PcBytes
mmx_91 wrote on 2023-09-14, 13:58:
I've run both an GF2 MX and a GTS on that mobo using an 200W ASTI LC-200C PSU I rebuilt with no issues. Both on the P6VBX7 and a P5MVP3.
Neither had any issues with either cards. They also ran Geforce 4 MX and Ti4200 cards with no issues, using the same PSU.
And just as shevalier said it - these have a converter that likely takes 5v and steps it down to 3.3, and that thing will run regardless whether it's running from AT or ATX power. Most of these AT 370/Slot1 designs are made to do so.
Reply 15 of 26, by shamino
As I said, it depends how the motherboard is designed. They're not all the same, and we don't have his board in front of us to probe out with a meter.
Some dual power boards do in fact draw power from the 3.3V pins of the ATX connector, and they don't all even need a jumper to do it.
Obviously boards like this have an onboard 3.3V regulator, but they are notoriously inadequate. That regulator could be in poor working condition, as could be the AT power supply which were problematic in the AGP era and which few socket-370 boards even tried to support.
He's having trouble with AGP video cards which happen to be a major power consumer.
Power should always be checked and verified on any PC, but especially one that is having issues. 5V and 12V are easy to check, 3.3V isn't much harder.
Reply 16 of 26, by PcBytes
What I'd check would be the caps. Those are 20+ years old caps.
Reply 17 of 26, by Nexxen
PcBytes wrote on 2023-09-14, 22:03:
Nope, that's 20+ years of LOW QUALITY caps... nuance there not negligeable 😀
This is PCChips level, good it didn't blow in his face straight off.
Reply 18 of 26, by andreipasca
OK....new problem. So I managed to boot into Windows 2000 setup (Windows 2000 SP4 Final Edition 2011). Windows 2000 detects IDE HDD, BIOS also does. It finishes copying the files for installation, restarts, and loops. If i manually try to prioritise booting from HDD it tells me to insert install disk... Windows 98 setup directly tells me that i do not have a hard disk. The PC originally came with one IDE and two SCSI drives that connect through a SCSI PCI adapter. any idea what to do?
Reply 19 of 26, by shevalier
andreipasca wrote on 2023-09-15, 00:58:
SCSI adapter -> to shelf.
And testing RAM. Bay the way which CPU and which FSB you run on its matherboard ?
shamino wrote on 2023-09-14, 21:24:
Yep, i.e. CUBX-L. 😀
There not solder DC/DC and has 4 solder wire from ATX rail to matherboard 3.3V.
Rumors that there are some special boards that determine everything themselves and switch the power supply are urban legends.
Nowadays, many motherboard schematics have leaked online. Everything is much more boring and banal, alas.
