First post, by nhattu1986
Hi
I just buy some zip drive in external enclosure,
upon power the enclosure, the zip drive led on the front stay solid green and there are no drive activity when i inserted the disk into the drive.
the eject button also does not work and i had to using the eject hole in the back of the drive.
the drive in question is the ATAPI 250MB zip drive.
When i look into the drive, it seems that the red led that the drive using to detect disk also stay on.
can I safely assume that the drive is toasted and it is part donor?
is there any remedy to save those drive?
Thanks
EDIT: The enclosure is Fujifilm finepix HA-770
I have another one that work perfectly fine with the same powersupply.
