First post, by wbahnassi
- Member
Hi,
Is it possible to use a rocker switch with LED to power up an ATX PSU? What would be the wiring in that case?
An example of such switch is this:
https://www.sparkfun.com/products/11155
It has three prongs: PWR, ACC, GND. Typically you power up an ATX PSU by wiring the green line to a black line. This rocker switch makes a closed connection between PWR and ACC when it's in the ON position. In the OFF position, nothing is connected. So I can connect ATX green to PWR, and ATX black to ACC. This would turn on the PSU when the switch is ON. But the LED only powers if GND is also connected to ground and the switch is in the ON position. So I'm thinking this won't work.
If this type of switches doesn't work, is there a correct switch with LED that can be used instead of the above?
Thanks!
