First post, by therelaxer
- Newbie
I have had this motherboard for a long time. I did have it working at some point well over a decade ago. I pulled it out and I cannot get it to post. I remember having it working. When it is powered on no components are hot or seem like they are having a problem.
No matter what ram; FPM, EDO, 2MB to 64MB sticks; or which CPU; AMD DX4 100 NV8T, SV8B or Intel DX 33. I even tried booting it with the power supply from my IBM 5170 thinking it may require -5v. No dice.
Other than buying some EEPROMS and a programmer IDK what else to try. It sure looks like a dead BIOS. Perhaps I did the no-no and attempted this: "Attempting to flash a UV-erasable BIOS in the motherboard will ruin the BIOS chip". The current CMOS chip does have the window. I can see its outline underneath the sticker.
The only things I do remember doing to this board was to solder in a dip socket for the RTC. Though I think I am going to buy one of those new fancy ones that takes the CR2032 AFTER I get it posting again. I have a beeper or speaker on the way to hook up to it to see if it has a beep code or anything. Please forgive the ISA videocard, I have a diamond stealth 64 on the way.
I have added some photos below of the board.
Any ideas? EEPROM and programmer time?
