First post, by songoffall
- Member
I must confess, I have never owned an AMD-based machine in my life. So this is a first, and a weird one at that. So here's what I'm building.
OS: Windows 98SE with DirectX 7.
CPU: I'm not sure at this moment. The writing on the CPU itself suggests it's an Athlon 700 from 1999. Windows 98 detects it as an Athlon XP 1700+ from 2001.
CPU cooler: Thermaltake Volcano 6 Cu. It sounds like a jet engine, even after oiling the fan. Guess a 60mm Noctua replacement fan would fix it.
RAM: SK Hynix DDR-333, 512Mb
HDD: Maxtor 60Gb IDE
Motherboard: FIC AN11. It's surprisingly similar to the venerable Asus A7V, down to the Promise Ultra100 onboard chip for IDE RAID. Except it comes with a VIA KT266 chipset - DDR support instead of SDRAM. VIA's 4in1 drivers from Phil worked like a charm (I used the old 4.35 drivers).
GPU: GeForce 4 MX440 64Mb. I know it's not an amazing card, but it should be enough for Windows 98SE gaming. The first PC I built for myself had a GeForce 2 MX200 - and that did more or less fine on early Windows XP. Driver version 31.40, courtesy of Phil's Computer Lab, was the earliest to detect the damn thing.
Sound: Creative Sound Blaster Audigy 2. Surprisingly, the drivers were harder to install than expected - the archived CDs on Archive.org were tampered with and had files missing, and the Sound Blaster Setup program, when the InstallShield executable was pasted into its folder, refused to acknowledge there was a Creative Sound Blaster card present. With a bit of tinkering I was able to install everything - it's working now with VXD drivers.
FDD: NEC 3.5mm
CDD: NEC 52x CD-RW
So, I'm open to suggestions. Any other fun stuff I could do with this build? This is my first AGP build in I think 20 years.
Also, I'm missing the IO shield. Which is quite unfortunate.
UPD: Apparently, I was spot on about Asus A7V - looks like its IO shield should fit FIC AN11 too, which is quite fortunate.
Compaq Deskpro 2000/P2 300MHz/384Mb SDRAM/ESS ES1868F/Aureal Vortex 2
Asus A7N8X-VM400/AMD Athlon XP 2ooo+/512Mb DDR DRAM/GeForce 4 MX440/Creative Audigy 2
Asus P5Q Pro/Core2 Quad Q9400/2Gb DDR2/GeForce 8800GT/Creative X-Fi
