VivienM wrote on 2023-10-22, 19:12:Why not go much newer? There are plenty of cheap sandy/ivy bridges being sold now by people just upgrading now, not to mention y […]
Why not go much newer? There are plenty of cheap sandy/ivy bridges being sold now by people just upgrading now, not to mention you can actually find things like CPU coolers for those processors.
Not sure about GPUs - my XP system has a 7970, but that doesn't seem to have the best compatibility with older games, maybe something like a 6xx/7xx nvidia card is a better idea.
The XP era really lasted from 2002 to 2010ish, with most new hardware continuing to have XP support into 2012-2013. Building a ~2004-5-era XP system to run 2004-era XP games is a bit masochistic; those games run soooooo much better on newer hardware.
(FWIW, my system at the time it was released couldn't run Doom 3. Something about Doom 3 caused mad artifacting with my ATI AiW 9800 Pro. Never figured out if it was drivers, heat, or anything else.)
I would say Pentium 4s and GeForce FXes and the like are Windows 98 hardware, not XP. Even though, of course, back in the day, 95%+ of those ran XP...
Thanks for reply. Going newer is on option of course but I want to play it safe concerning the backwards compability. The reason why I want to build xp rig is to have a platform that runs the xp games the way they were meant to run. After running much trouble to get these games working on my windows 11 machine I want to take the easy route now and want to get as much comtemporay hardwise as possible.
But sure thing if newer stuff is more easily available and has no problems concerning the backwards compability I will look into newer stuff as well asap.
[my own Windows XP build started out as a Core2Duo before eventually upgrading to an i7-3770k (see link in my signature). Part of this was driven by upgrading to a 1920x1200 resolution monitor and wantiquote=Shponglefan post_id=1204929 time=1698002062 user_id=34232]
Mng to maximize performance in 3D games in that resolution.
Personally, I would go Core2Duo as a minimum, if not faster. I wouldn't really bother with a Pentium 4 or Althon XP for Windows XP, until you're specifically going for a period correct build. Those are better suited to Windows 98 builds.
GPU kind of depends again on intended resolution and performance. I would tend to go faster if possible (e.g. something more modern).
RAM I would just max out at ~4 GB. 32-bit Windows XP can only use up to ~3.2 GB anyway.
[/quote]
Thanks for your reply as well. As mentioned above backwards compability is the main reason I was considering the early cpu. I just want hassle free win xp gaming experience with nice sounds. If more modern cpu are capable of giving me that experience I am more than happy to consider dual core cpu and move away from the old athlon and p4 cpu.
Same games for the graphics cards. If more modern cards are capable of giving me a hassle free xperience I will pick them.
