First post, by NJRoadfan
Picked up one of these on Amazon for projects. Tried a whole bunch of smaller SD cards from various brands I had on hand (mostly 8GB and 16GB). NONE of them work. The unit only intermittently detects the card with the correct size OR as 32MB. In either case I can't actually write anything to the card with the adapter. Doesn't matter what IDE controller I use either. I've tried onboard (Intel PIIX4), a Promise Ultra 133 PCI card, and even my USB-to-IDE adapter on a modern machine. All exhibit the same behavior of not being able to write to the card and/or not detecting the size correctly. I've tried blasting the SD card's formatting and any partition map that might be on them as well.
Anything else I should try before declaring this thing a dud and throwing it in the trash?
On a related note, the SATA-to-IDE bridge I bought worked perfectly fine with a random 250GB hard drive in a 440BX based system (albeit capped at the 28-bit LBA limit).
Reply 1 of 7, by kingcake
I use the "GINTOOYUN" brand ones off Amazon. Used probably 25 of them at least. No problem. If I do run into a PC not liking the card/capacity it's always the BIOS's fault and XT-IDE/Drive overlay fixes it.
Sorry I can't help much for your brand.
Reply 2 of 7, by NJRoadfan
The "brands" are meaningless. Mine is branded KOOBOOK. They all use the same FC-1307A chip and come out of the same factory. This one is looking like its going in the trash.
Reply 3 of 7, by Horun
I would not say they all come from same factory, China has many electronic manu plants, some good some bad....🤣
Reply 4 of 7, by weedeewee
They do not all use the same firmware or pcb layout.
I tried one in a compaq armada m700 and it failed to work in udma mode together with the dvdrom drive, both are on the same channel.
I then bought another one, same chip, which looked more like a 2"5 drive, and that one worked like a charm.
It's a HUGE difference having the device running in PIO mode vs UDMA mode.
Do not ask Why !
Reply 5 of 7, by kingcake
weedeewee wrote on 2023-10-24, 04:58:
They do not all use the same firmware or pcb layout. I tried one in a compaq armada m700 and it failed to work in udma mode toge […]
How are you putting them in UDMA mode? Just using an 80 conductor UDMA ribbon cable?
Reply 6 of 7, by weedeewee
kingcake wrote on 2023-10-24, 05:05:
Since it's a 2"5 adapter in a laptop, I couldn't tell ya. the drive works in udma33 mode and the dvdrom works in MWDMA mode... but yeah, I guess an 80 wire cable would be required.
Do not ask Why !
