First post, by bmwsvsu
After about 5 hours of playing around and attempting to troubleshoot this, I'm about ready to throw in the towel.
Motherboard: Compaq uWave
CPU: Duron 900
Ram: 256MB PC100
Video: AGP (currently a GeForce2)
So here is what DOES work:
-Hard drive detected fine by BIOS
-Machine will boot to a Hiren's boot CD just fine.
-Hiren's XP boot environment works fine
-Hard drive shows up in XP boot environment - I can partition it, format it, copy and paste files to and from it. I can use Ghost to image it.
Here is what does NOT work:
-Booting a Windows 98 installation disc, after it says "Setup is checking your system configuration," it IMMEDIATELY halts with a R6003 Integer Divide by Zero error.
-Booting into DOS from Hiren's - running FDISK immediately gives a "Divide error"
(neither of the above errors occur if I boot without the hard disk connected to the board - Win98 setup simply says it can't install since there's no hard drives and FDISK says no fixed disks installed).
-Booting into a pre-imaged drive which works perfectly fine on another Windows 98 system immediately spits out the error "Error Loading Operating System. Setup cannot continue." This is opposed to a different error if I attach a blank drive which simply says something along the lines of no operating systems found.
I've tried different ram, a different video card, a variety of hard drives ranging from an old 20GB ide drive to a 32GB SSD DOM to an 80GB ide drive to a CF-to-IDE adapter, all to no avail. Always the same results.
Anybody here have any ideas? There's not really much to play around with in the BIOS as far as settings, and as I said, I CAN communicate properly with the hard drive from within an XP environment booted from Hiren's.
EDIT - to add to this, I've tried 2 different motherboards just to rule out a bad board and tried different ram and even a PCI video card, and all still the same. Quite literally the only thing I haven't swapped out for something different is the CPU.
Reply 1 of 10, by Deunan
bmwsvsu wrote on 2023-10-25, 16:37:
What HDD is that? Size? My guess is the BIOS has a bug that prevents it from working properly with certain HDDs. This could also be a problem with MBR data - XP works because it's a newer OS that uses BIOS only for the initial OS loader, then the loader takes over and finally NT kernel. Win9x uses BIOS a lot to load stuff into memory before its kernel can run properly. Although copying a working disk image should overwrite the MBR.
Could be it's a combination of factors - BIOS limitations and some sort of issue with MBR. Is is possible to run FDISK /MBR from the floppy boot? What about zeroing the first HDD sector, does fdisk also throw an error in that case?
Reply 2 of 10, by bmwsvsu
20 GB IDE mechanical drive is what I'm testing with since it is the closest thing to period-correct I have.
So I created a Windows 98 startup floppy disk, booted to that fine and ran FDISK. It detected the IDE drive and allowed me to partition it. Ran Format command to format it, but now upon booting into Windows 98 startup CD, it just plain locks up immediately upon choosing the option to run Windows 98 startup.
Reply 3 of 10, by paradigital
You did mark the partition as active, I assume?
Try formatting the hard drive as a system disk (/s), and copy the contents of the CD to the HDD (into say C:\98SE\) and run setup from there after booting from the HDD?
Reply 4 of 10, by ElectroSoldier
Oh this is interesting....
If you can get as far as a command prompt from a Win98 boot floppy fdisk the mbr then take the disk out of the machine put it into another PC as a slave drive partition it and then format it using the OS on that machine.
Once it has a partition and format put it back into the PC and boot the Windows 98 boot floppy and try and run fdisk. report results.
Reply 5 of 10, by bmwsvsu
re: paradigital - Yes, active. And your suggesting was actually the very first thing I had tried as my standard way of doing things is to use Hiren's XP to partition the drive into 2 FAT32 partitions, copy the Windows 98 CD contents to the latter partition, then boot DOS from Hiren's and launch Windows 98 setup from there. The issue I ran into on this machine was that after doing all that and then booting into DOS, DOS simply couldn't see any of the partitions. But now that I've gotten a Windows 98's boot floppy disk to detect partitions, I can re-try that except use the boot floppy instead of Hiren's own DOS. I just used FDISK to create 2 partitions (1 primary, 1 extended w/1 logical drive) and am waiting for those to format (using format command). I will boot back into Hirens XP and copy over Win98 CD contents to the latter drive, then try from boot disk to launch setup that will reside on the D drive.
re: ElectroSoldier - that will be the next thing on my list if the above fails.
Interesting aside: Before reading the last 2 responses, I tried just straight-up installing Windows XP from an XP CD. Installer ran fine, copied all the setup files to the IDE drive, but on the first re-boot (where it is finally ready to boot from the hard drive for the first time), I got the following error:
Couldn't open drive multi(0)disk(0)rdisk(0)partition(1)
NTLDR: Couldn't open drive multi(0)disk(0)rdisk(0)partition(1)
Second aside: I tried copying a working image file I had of a dual install of 98/XP. Upon booting, it simply says NTLDR is missing.
Reply 6 of 10, by bmwsvsu
Well this is interesting....SUCCESS maybe?
1 - Boot to DOS floppy disk
2 - FDISK (create a primary partition of 17GB and an extended partition with a 1.5GB logical drive)
3 - FDISK /MBR
4 - FORMAT C-drive and D-drive (default settings)
5 - Boot into Hiren's XP. Copy Windows 98 CD contents to D-drive
6 - Boot to DOS floppy disk
7 - CD to D directory then run SETUP
8 - Setup works, copied files, then after reboot it BOOTED INTO HARD DRIVE (now finishing installation)
We'll see how this finishes up. Also will be curious if an image file I create using Ghost of this will work or not.
Bizarre to say the least that this works when nothing else would (and by nothing else, I'm talking methods that work fine all the way down to old Pentium II hardware).
Reply 7 of 10, by bmwsvsu
Ok, so a Norton Ghost imaged drive will NOT work. What is Ghost doing that breaks this? Plugged the drive I used to create the image back in and it works fine. I've never, ever encountered this problem with the numerous different pieces of Windows 98 hardware I've set up through the years.
Reply 9 of 10, by ElectroSoldier
bmwsvsu wrote on 2023-10-25, 20:26:
I couldnt say, I never had much luck with Norton Ghost.
I tried it several times over the years and it never really worked as it should for me.
Reply 10 of 10, by bmwsvsu
What I eventually figured out is that this motherboard does not play nicely with any kind of solid state drive. Hyperdisk 32GB disk-on-module (40-pin IDE), 2 different branded 32GB CF card (industrial) over 2 different adapters, all of this caused nothing but problems and I never succeeded at getting them properly formatted, let alone Windows installed on them.
So on to a traditional mechanical IDE hard drive, these are fussy too, still never managed to get Windows 98 startup CD to work when one is installed.
What finally worked using an 80GB drive was:
-FDISK and FORMAT IDE drive from DOS boot disk (but even here would only allow up to 16GB of total storage)
-Copy Windows 98 CD over to 2nd partition, then from a DOS prompt launch the setup, allow first phase to finish before first reboot
-remove disk, connect externally to another computer, use AOEMI partition manager to expand partitions out to 72GB and 3GB
I found a really old version of Ghost (7.5 I think) that fit onto a floppy disk and was able to successfully clone my expanded partitions to an identical 80GB hard drive, and that drive booted fine as well.
