First post, by BleedCap
3d printed custom bracket for socket 478.
I used this https://www.thingiverse.com/thing:2681174AM4 bracket stl file as a base design.
Its to be use with cheap generic clip based cpu cooler.
I'm looking for an alternative to my stock Socket 478 cooler. Does this work with AM4 clip-coolers, or what kind of cooler should I look for?
If I can find someone to 3D-print this 😀
r00b wrote on 2024-02-07, 22:17:I'm looking for an alternative to my stock Socket 478 cooler. Does this work with AM4 clip-coolers, or what kind of cooler should I look for?
That should work with any AM4 clip cooler. The Wrath cooler with the heat pipes would probably do a nice job cooling the P4s and they aren't to expensive either
Quick search yielded nothing where I live, but thanks. One more thing to keep a look out for 😀
