Ide Doms
First post, by robbiec
Hi All,
Built myself a K-3iii/400 setup a few months ago on a DFI P5V3+ v2 originally to mess with my daughters head by giving her a Dos prompt but which got out of hand and morphed into 384MB Sd100, Soundblaster 16 and a choice of graphics cards ranging from a Trident through Matrox to an Nvidia Mx something or other. Working floppy drive and CDRW have also landed and i found a new Ch Products Mach 3 joystick to give me some control in XWing.
I've been looking at IDE DOM units on Ebay and other places as they look nice and tidy but i can't seem to find any usage detail on retro pc builds. Does anyone have experience?
Usage will be Dos 6 and OS/2
Reply 1 of 8, by dionb
I have a couple and use them on my U5S (486SX) 33 (256MB) and P3-500 (4GB) DOS builds.
So far they are fast, and trouble free, although I haven't exactly been torturing them with writes.
Reply 2 of 8, by robbiec
dionb wrote on 2023-10-27, 22:38:
Good to know, thanks for getting back so quickly. Just put an order in for a Hyperdisk 8GB, specs states 150MB/s so we'll see how it goes.
Reply 4 of 8, by robbiec
ElectroSoldier wrote on 2023-10-28, 00:16:
A lot of them come without the power cable, which they need.
Luckily the one I ordered comes with the molex adapter - majority of the Ebay jobs seem to ship sans power cable.
Reply 5 of 8, by douglar
I like IDE DOMs because they make for a very clean looking build but there are a couple things to remember:
  • They have clasps that attach very firmly and can crack the plastic guard rails around the IDE headers if you are not careful
  • If you have a Pentium or newer system and want to do speeds faster than ATA-33, you need to either ground pin 34 or attach with an 80 connector cable
  • If you are doing the faster speeds, the larger capacity DOMs with multiple flash chips often seem to have higher max throughput capacities
  • The guts are usually simiar to an industrial CF, but like industrial CFs, there's a lot of different guts that can go in there. Here's photos of 3 recent ebay purchases:
1.25 MiB
And here are some older ones…
146.42 KiB
64.75 KiB
Reply 6 of 8, by ElectroSoldier
Another good call above.
Those plastic clips! I chopped mine off with a pair of side cutters. It locks into the base of the IDE connector and wont let go at all.
Nice link there, I didnt realise it runs as ATA-33. But I use mine with NT4 so I guess I never would notice on a file server that just has the OS on it.
Reply 7 of 8, by douglar
Out of all the different controllers pictured, in theory, the EDC 4000 / Innodisk looks the most interesting with the wide range of supported IDE modes and support for wear leveling. I'll test them out some time next week.
https://www.innodisk.com/en/products/flash-st … c_4000_vertical
https://www.design-reuse.com/news/4650/hypers … y-solution.html
https://www.jotrin.com/product/parts/W5AB0042
https://www.greenliant.com/dotAsset/39671.pdf
Cant find out much about the Silicon Magic SM223TF AC
Reply 8 of 8, by Sphere478
They can work, but fastest would be m.2 sata on a pci sata card.
There is a all in one card for sale from rabit computing if I am remembering the company name correctly.
Personally, I use promise sata II tx4 card with a 2.5” to m.2 adapter
Edit: https://68kmla.org/bb/index.php?threads/a-hig … birthday.43133/
Sphere's PCB projects.
