First post, by Erwin_Br
I’m checking the jumper settings of my “new” asus vl/i-486sv2g mobo and I’m seeing a weird combo of jumpers that shouldn’t be possible to configure the L2 cache settings. (i.e. the combination is not mentioned in the manual) So I need to correct it, but I’m not sure about the capacity of the sram installed.
How do I determine the correct cache size of my sram? I did a search for “ um61256fk-15” and it seems to be 32KB. Is that reliable?
Thanks!
