I'm not very sure of what you're asking for, but let me try:
That card is made of two functionally independent parts - a proprietary (relatively to estabilished PC standards) 16-bit to 8-bit interface converter, and a memory-mapped option ROM socket (which is typically used for the "XTIDE Universal Bios", an option ROM that in this case provides a bootable driver for the other part but can have other purposes and be used standalone)
It is intended for older computers (those with an 8-bit bus, which tend to be called "XT"s in the generic meaning 😀 ), you can use it with a 16-bit ISA computer and it will work fine for its intended purpose, but you'll do better with a 16 bit IDE card (which can be rather simple: Re: Best ISA super i/o chipset? )
"Its intended purpose" isn't CDs or other ATAPI things, for neither of the two parts (even though future expansion to those is theoretically possible)
You could buy/make a longer cable (probably off standard, but it's not like you're going to use the top speeds of even 40-pin IDE) or get one of those IDE cards (possibly even as part of a superIO or sound card), as long as it can be configured to be the "secondary channel", and use that for your CD drive (I bet there's enough stupid software that requires an HDD as primary master, and the secondary channel won't be bootable anyway... unless you rewrite the firmware or add an option ROM that provides the functionality, as could be the XTIDE Universal Bios if you wanted to use 2 HDDs 😁 )
The latter is probably the smarter choice - both drives can be accessed "simultaneously" and you skip the fun of master/slave interactions in early 90s stuff!
