First post, by karelbre
Hi,
I am trying to setup my old retro PC with 386SX and 16GB CF card via CF->IDE reduction card. Motherboard (AMI Bios 1990) doesn't have integrated IDE controller so I am using ISA card for IDE and Floppy. It works correctly with my old HDD (~250MB). However if I try to connect CF card and configure it in BIOS to any type (including User Type 47 1024/16/63) it hangs after RAM test with Wait message and won't continue. If it's not configured at all it normally continue to boot process.
CF card is detected fine by EZ-Drive (trying DDO) and it also works on modern system. Motherboard supports only CHS, no Large, no LBA, no auto-detection.
I was not able to find this specific situation on forums. Had anybody similar issue?
No idea what could I try if I want to still use bigger CF card than 512MB.
Thanks for advices!
