First post, by Danger Manfred
I found these IS61C1024-10N SRAM cache modules on Aliexpress, and was wondering if they can be real.
I have a very fast 486 motherboard, an AMD AM5x86-133 CPU and 2x32MB of 72pin 60ns FPM RAM, but am currently stuck on 256K cache, which is only sufficient for write-through mode, so if I want to use write-back mode (or ever find another two of these RAM modules), I need to upgrade cache.
However, I was told there were fakes on the market. And a good price should probably make me suspicious?
https://de.aliexpress.com/item/4000490277482.html
Should I just try it?
Reply 1 of 4, by vstrakh
Those aren't "cache modules", those are static ram ICs.
As always - you never know if something is real or fake with chinese. I was buying old DRAM chips to repair ancient devices, and one of my three orders was fake, failing the acetone test.
I'd be cautious about 10ns option in DIP package. 20ns might be real, but right now mouser has only 12ns and those are in soj package, not dip. The 10ns DIP might be relabeled slower grade IC, if sram IC at all...
Reply 2 of 4, by Danger Manfred
vstrakh wrote on 2023-11-10, 11:52:
Forgive me for using the wrong term here, the plan is to use SRAM ICs as L2 cache, though.
I have since found a decade-old thread here on VOGONS (Super Fast 486 Cache - 10 ns) that I didn't want to necro, where somebody had ordered ICs that looked exactly like these in bulk, and had no trouble with them.
What I really wanted to know is my chance of receiving SRAM ICs that have the capacity printed on them, so my 486 will be able to cache its 64MB of RAM in write-back mode.
I guess I'll just have to try.
Reply 3 of 4, by mkarcher
General consensus on VOGONs is that these chips have fake markings. To the best of our collective knowledge, there never were 10ns SRAM chips in a DIP package manufactured by ISSI. Nevertheless, you can expect to receive 5V 128k x 8 (1MBit) SRAM cache chips that can be used to upgrade your 486 system to 512 or 1024KB of L2 cache, but the chips are 12ns at best, possibly 15ns. Also, several people reported a dead-on-arrival rate of around 10%, so expect some failed chips. Returning them to AliExpress is likely not worth the hassle, so you might want to order a spare one with your initial order.
Reply 4 of 4, by Danger Manfred
That's fair. The offer on Aliexpress is for packs of 5 anyway, so I'd buy 10, and if 1 or 2 are defective, that would still be fine for the 8 SRAMs I need.
Luckily I still have a 512Kbit TAG RAM, that should be sufficient for 1MB Cache.
