First post, by pupuklok
Hello . I have buy a ibm ps/2 486 slc2. First i replace the battery of the mainboard because the old one was dead . Then i use a emergency disk from ibm to setup the computer . It says that the scsi harddrive is bad . And i cannot further until this is solved. Now i can not setup the computer without a harddisk. On ebay there are many scsi harddrives but many are not willing to ship to netherlands . And mostly these are not tested. What can i do ? Is there a better solution than buy a new scsi harddisk ? Where can i buy a original hard drive for this ibm computer? Maby it is better to buy a another computer ? I want to play old dos games but now i have nothing. The computer does not boot without a harddrive. These machines i can not recommend for a novice user.
