First post, by matti157
Do you know if there is an adapter for this connector?
Reply 1 of 3, by weedeewee
That's a photo of an IBM branded floppy drive 😀
A photo of the connector would've been nice.
though in all likelihood. the answer will be no.
To what connection would you like to adapt the connector ?
Do not ask Why !
Reply 3 of 3, by Horun
Hmm googling says for a thinkpad , should be 26pin and you would need to measure the width. IBM made them in 17mm, 20mm and 21mm iirc.
here is image of the back of same drive and cable end,
https://i.ebayimg.com/images/g/P0sAAOSw1ellLoke/s-l500.jpg
https://i.ebayimg.com/images/g/xlAAAOSw5YdlLokd/s-l500.jpg
