First post, by theamtrakvirus
So after a nightmare trying to get Windows XP (32 bit) installed on my Alienware M17x r1, I managed to get it almost fully working... except for sound. At first I tried the default driver Snappy Driver Installer gave me for it but that would just give me code 10 errors no matter what and not work at all. I tried a number of different drivers I found searching around supposedly working on XP but only 1-2 actually would even install. Eventually I tried a couple others in SDI that would finally get rid of the code 10 error but then I encountered a completely different issue now. The sound will not route through the inbuilt speakers on the laptop. It will route through the headphone jack fine and when I boot into a live operating system (such as Hiren's Boot CD x64 which has a startup chime) the speakers work fine so I know it's not a hardware issue. I've tried plugging and unplugging a pair of headphones both at the desktop and with a game running to try and get it to recognize the speakers but it doesn't work. With headphones it works perfectly fine so I'm fairly certain the driver is doing what it's supposed to do, but these drivers seem a bit... crap for lack of a better term. The ones I've gotten working seem to treat it as a desktop and not a laptop going off what software it comes with shows so I'm not sure if that's part of the issue or not. I don't really want to install 64 bit xp on here since I'd like to retain compatibility with older things if I want to run them if I can absolutely avoid it.
