First post, by xorlof
Looking at the major chips on a 286 motherboard I have beside me, I haven't found anything that looks like it needs voltages other than 5V. With a careful selection of surrounding components, do you think it possible to boot and use such a system with 5V only? Can anyone think of any way there would be damage to the system if I tried?
Aside from the motherboard itself, I need to power
- the ram and processor, which are 5V
- a vga card--the one I have on hand looks to be 5V only; it doesn't even have isa pins for -5V, -12V, or +12V
- a sound card--ditto, although a handful of cards use -5V at the very least
- the keyboard, which should be fine
- a compactflash drive, which should be ok with 5V
- an isa i/o card to interface with the drive--This is the biggest question mark for me. The multi i/o card I have on hand (typical assortment of serial, parallel, floppy, ide, game) does look like it wants +12V and -12V, but I'm not sure which devices need which voltages. I'm guessing serial serial might not work, but how about the IDE port?
Thoughts? Thanks in advance.
Reply 1 of 4, by BitWrangler
Probably the serial is most likely, disable on the i/o card and in CMOS if possible to avoid weird errors and hangups. If possible you might wanna stick a 10 kilohm to ground on the 12V to avoid anything that reads it or references it going into "undefined" state, i.e. putting spurious bits on a bus somewhere. Floaty pins are best avoided.
Reply 2 of 4, by Cyberdyne
I have ran many motherboards with only +5V. Some do need to route 5v to POWER-GOOD line. Some motherboards do not need even that. Had good results with 486 to even P3 motherboards. So made minicomputers with a 5v power adapter and a cheap newer ISA sound blaster clone, usually they also do not need other voltages. Some sound amplifiers do.
Reply 3 of 4, by xorlof
Thanks for the replies. I'll give it a shot and will be sure to hook up power good.
BitWrangler wrote on 2023-11-17, 20:41:
Anything special about that 10K value? I've got a bunch of 2.2Ks on hand. Good 'nuf?
Reply 4 of 4, by BitWrangler
Not super special, I just go higher than a kilohm because some of the extra super low power CMOS can backfeed off a milliamp. I'd use 2 in series of the 2.2K I guess.
