First post, by kolmio
Should Logitech Unifying with with Windows 98 SE? I can't make it work yet.
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium II 450 | Matrox Millennium G450 | SoundForte SF16-FMI-03 | 32 GB MicroSD
Reply 1 of 9, by Horun
It is a USB wireless receiver and Logitech website says Windows 10+. Release date in 2017 so I do not think you will every get it to work in Windows 98 or XP.
Would be different if it was first released back during XP era.... then there might be a chance. Just my opinion....
Reply 3 of 9, by progman.exe
kolmio wrote on 2023-11-24, 20:29:
Me and a mate think it should work. Get the keyboard and receiver working paired under a newer OS (works here with Linux and a program called Solaat), and then just move the receiver.
As long as the USB bit provides a USB keyboard, I guess 98 should see it...
Reply 4 of 9, by darry
progman.exe wrote on 2023-11-26, 18:44:
That is what I had done. Did not seem to work under 98. Worked under XP. Was in USB passthrough in both cases. Running 98 might change something.
Reply 5 of 9, by weedeewee
Would adding the logitech VID to the correct .inf file work ?
Do not ask Why !
Reply 6 of 9, by mrfusion92
I use my Logitech MX Keys and MX Master 3 in 98 without issues. But I don't know if they are supported out-of-box or it is thanks to the NUSB package which I always install in any 98 box of mine.
Reply 7 of 9, by kolmio
My keyboard only works in BIOS. In Windows 98 it doesn't. I haven't tried anything special for it though.
But I have another problem with any USB HID devices. When it's plugged in, I sometimes get badly distorted image.
Reply 8 of 9, by dormcat
kolmio wrote on 2023-12-04, 20:16:
The most common cause of this problem is that many early BIOS had "USB legacy keyboard/mouse support" disabled by default.
Well that's something new......
Reply 9 of 9, by kolmio
dormcat wrote on 2023-12-05, 01:13:
Thank you, it helped. That option was in Integrated Peripherals tab.
