First post, by dcguan@gmail.com
I have a Logitech serial mouse m-md15l. The mouse works under DOS using ctmouse but does not work under Windows 95.
Add new hardware detect the mouse as standard PS/2 mouse but does not work. The device status shows code 24.
Even I force to use build-in standard serial mouse driver or Logitech serial mouse, the condition is the same.
Since this mouse can be detected by ctmouse, I think this is not a hardware issue.
How can I get this mouse work under Windows 95?
