First post, by NTG2001
- Newbie
I recently picked up a system with a CMD PCI0640B on board. I've already accepted that using it as an IDE controller in not wise especially since I'll be running DOS and not a newer OS like Linux that "fixed" its issues. However, this controller also acts as a floppy controller, and it too falls issue to one of the most baffling oversights I've ever seen where it can have conflicts with the IDE portion if they're being used at the same time. (Did they have zero QA testing or something?)
My question is this: Is it still okay to use it's floppy controller if I'm using a different IDE controller (or even SCSI)? Are there any other issues with it's floppy controller or is it just when being used with the faulty IDE controller that issues arise?
