First post, by tony359
Hi there
I have this PS/2 case which has seen better days.
Any ideas? I think I'll sand away the corrosion, spray a primer and then apply the most similar paint I can find. After all most of the metal case is hidden by the plastic case wrapped around it.
Any ideas on what paint to use?
Or maybe just a rust remover and some oil?
    314.68 KiB
    337.51 KiB
    377.6 KiB
    324.77 KiB
    373.04 KiB
My Youtube channel: https://www.youtube.com/@tony359
Reply 1 of 3, by Shponglefan
For rust removal I prefer soaking in Evapo-Rust. This will remove rust from places that might be difficult to sand especially if you're dealing spots that are pitted.
I've got a post in my Tandy 1000 TL restoration thread where I show the process, and before and after pics: Re: Tandy 1000 TL Build / Restoration
For coating and rust protection, one option is galvanizing sprays (e.g. zinc spray) as an alternative to regular paint.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 3, by tony359
Thanks for sharing those nice pictures!
I had experience myself with citric acid (a very good alternative to evapo-rust) for some Macintosh cases. It works like wonder. But this is chromed? surfaces, most of the rust is not exposed. On those yellow-looking macintosh frames, the lemon juice removed the "yellow" coating as well, leaving bare metal which would rust by just rinse it. As you said, I did use galvanising spray afterwards, the result was brilliant. For a case like yours, it's my favourite process too.
Here is my process with the Macintosh: https://youtu.be/crMj03OQlhQ
But this frame is almost glossy so I'd like something similar to replace the coating with.
Now, the PS/2 floppy had some similar corrosion inside and I sanded it with a wire wheel. What I found was that there was no "coating" coming off. I'm not sure what the process was but in the end I just applied a thin layer of oil and happy days - though you can still see where the metal was eaten away from the rust.
I think I'll start with some scrubbing and rust removal. If that works, happy days. If not, I'll prime and re-paint.
Thanks for now!
Reply 3 of 3, by tony359
The rust damage was way too much so it will need a coat of paint.
I had to use a abrasive rubber bit to crack open the little blisters which were hiding rust. A night in citric acid and A LOT of scrubbing and sanding got rid of the rest.
Now it will be primer, then paint. Looking for a suitable paint now.
    315.52 KiB
    283.62 KiB
