First post, by vico
- Newbie
I have a DFI CA64-EC motherboard that has integrated AC'97 sound, which is enabled from the BIOS with the "Onboard Legacy Audio" option, it even has the "Sound Blaster" option, however, when I try to install its drivers In Windows 98 or MS-DOS, a message alerts that Legacy Audio has not been enabled from the BIOS.
I've even tried updating the BIOS but I haven't had any luck.
If this can be solved, maybe someone here can give me some advice.
