First post, by Taylor235
Hi all
New here and on this scene so excuse me if I’m missing the blatantly obvious somewhere!
My first time attempting to put a nice old school rig together. Have picked up a socket 7 board - an MSI MS-5158 TX5. Came with a pentium 166 MMX and 32MB of EDO RAM. Seller showed the board tested and working prior to purchase. I’m no expert but I know enough about more modern systems so when I plugged everything in and got no output to the display and no POST beep, I did the normal troubleshooting - reseated the CPU, RAM, resetting the CMOS, replacing the battery but still not booting. Tried running without any expansion cards, without RAM, without the CPU in all different combinations but I am completely lost on this one.
When powered on the CPU fan does spin up, and the light on the SATA-IDE adapter I’m using turns on. Seller suggested that some boards require a -5v rail to work but I didn’t think that was usually the case? Also mentioned an issue they’d noticed where it would occasionally boot with the wrong clock speed recognised and they had to “jiggle” the dip switches - I’ve confirmed that both the jumpers and dip switches are set correctly, even tried underclocking but still to no avail… and I can’t even get as far as the POST to see that anyway! So really stumped here! Any advice would be appreciated.
Reply 2 of 17, by Taylor235
supercordo wrote on 2024-01-05, 23:57:
Might want to get a diagnostic card. Is anything getting warm?
I’ve got one of those on the way from amazon tomorrow so hopefully gives a better idea.
Nothing feels warm to the touch even after left on for a while that I can tell - but I could just be missing something again
Reply 3 of 17, by Repo Man11
Is the board in a case, or are you bench testing it? A standard suggestion in cases like this is to remove the board from the case (assuming it is in one) and set it up on a table top. Since I have one, I always set mine up on an anti static mat; before I had one, I used to use a cut open anti static bag. A POST speaker, ram, and video card and nothing else.
Do you have any SDRAM around to try instead of the EDO?
Reply 4 of 17, by Taylor235
Repo Man11 wrote on 2024-01-06, 01:26:
Bench testing - I did have it in a case initially but pulled it out when I realised I was having issues. Sat on the anti static bag it came in. I’ve tried running with no RAM at all as I figured that would give some sort of beep error code through the speaker but nothing - I dont have any spares of anything which is the annoying part. But currently nothing hooked up but the cpu and ram - have tried both with and without the video card installed
Reply 6 of 17, by BitWrangler
Off the top of my head, I think the voltage setting on that board is quite low with no jumper, which if voltage jumper making a bad connection may be too low to attempt POST/BOOT so give the voltage jumper a good jiggle up and down to scrape off possible oxides and see if it shows life then.
Reply 7 of 17, by CoffeeOne
Taylor235 wrote on 2024-01-05, 23:44:
Hi all New here and on this scene so excuse me if I’m missing the blatantly obvious somewhere! My first time attempting to put a […]
Hi all
Your ATX to AT power adapter is working properly?
Reply 8 of 17, by Taylor235
BitWrangler wrote on 2024-01-06, 04:25:
Have just tried this - also tried swapping the jumper for a spare but still no signs of life. 🙁
CoffeeOne wrote on 2024-01-06, 09:02:
Hi all
It’s an ATX board so takes 20 pin power.
Reply 9 of 17, by Taylor235
Update! I’m not actually sure what I did to fix it but I do now get some form of POST - in one long beep and three short beeps - which I believe to be a memory error? Is that correct and how can I go about troubleshooting it? I’ve removed one of the sticks so now only one inserted, have tried this for both sticks individually but still getting the same beeps.
Reply 10 of 17, by zuldan
Taylor235 wrote on 2024-01-06, 11:55:
Clean the memory stick connectors with IPA and blow out the memory slots with air or use a clean toothbrush. Also double check all jumpers are configured correctly.
Reply 11 of 17, by Shponglefan
Depending on the BIOS, it could also indicate a video card problem.
I'd try a different video card if possible.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 12 of 17, by CoffeeOne
It is weird that you said nothing is getting warm, because the CPU is starting otherwise there would be no beeps.
Never mind.
So what RAM are you using? 2 times 16MB EDO 72pin? If yes, you cannot just use one, it needs to be installed as a pair (pentium uses 64 bit memory).
So try a different RAM pair.
Reply 13 of 17, by PcBytes
One long and three short beeps is Award BIOS' way to signal that no GPU was found. It's not the main RAM you need to swap now, but the GPU.
Reply 14 of 17, by CoffeeOne
PcBytes wrote on 2024-01-06, 16:07:
Might be true.
But when he gets the same beeps with 2 or only one 72pin modules, then it must be the RAM. The board needs 2 72 pin modules.
Reply 15 of 17, by PcBytes
IIRC if it was a incompatible RAM it'd scream a long beep, and we don't know what GPU is used.
Alternatively, if the beeps are a slight pitch lower in tone, that is a S3 GPU specific beep. You only get that if you don't connect a monitor to any S3 card pre-Savage 4.
Reply 16 of 17, by PC@LIVE
So, first of all, if the MB has an ISA slot, I would use a VGA ISA, from there either the acoustic signal (beep) disappears, or nothing changes, in my opinion with the VGA ISA, you could have a screen on the screen (BIOS) , but you need to use a pair of 72 PIN RAMs, possibly identical.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 17 of 17, by dionb
Agreed with above - 2x 72p SIMM needed. Apart from that, keep it simple: disconnect everything except CPU, VGA and those two SIMMs. It's not likely that SATA-PATA adapters are causing the problem, but only way to be sure is to remove them and everything else from the equation.
